Thread: Active Info Display & Discovery Navigation (Standard)
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Active Info Display & Discovery Navigation (Standard)
    46 Post(s)
    Quote Originally Posted by Chris View Post
    I must try that when the car comes back later on, I have an early MY2016 GT Bi-Turbo so my software and hardware may not be same as the current MY2017.
    Will give it a go however!
    Nope didn't work, not too worried however as I usually just keep the dash on the digital speedometer anyway.
    Must be a newer revision of the cluster or software in it.
  2. Re: Active Info Display & Discovery Navigation (Standard)
    May 2008
    My car was delivered in Sept 2016 and I think it was new to the spec at that point.
  3. Re: Active Info Display & Discovery Navigation (Standard)
    46 Post(s)
    Mine was built early in 2016 so still a MY2016 but registered on a 66 plate, it was a showroom car so came pretty well specced bar the Discover Pro. It came with heated steering wheel, reversing camera, AID and is the GT spec trim.
  4. Re: Active Info Display & Discovery Navigation (Standard)
    May 2008
    Having said that, I have only viewed the sat nav on the AID a couple of times at the beginning and it didn't suit me.
    I have had built in sat navs on my previous cars for circa 15 years and I guess I am used to looking across to the radio unit. I also find the alternative information can be displayed in a format I prefer on the AID compared to the Discover unit.
    So to sum up it is all down to personal preferences and I am happy with the way I use it!
  5. Re: Active Info Display & Discovery Navigation (Standard)
    Jun 2009
    Bangor
    Thanks vey much. Pick it up tomorrow so will let you all know. It's new but pre registered 31/3/17.
  6. Re: Active Info Display & Discovery Navigation (Standard)
    Apr 2012
    Somerset
    Not entirely linked as I have both the Discover Pro and AID, but I must say that one of the stand out features of the AID is when it's displaying the navigation map. It is so much easier to glance down at the map there than on the Discover Pro. Therefore, if you can get it working then I highly recommend having the map showing on the AID.
    Now: 2016 Passat SE Business Estate | V&C Pack | AID | DLA | TPMS
    Old: 2012 A4 Avant SE Technik | TDIe | Tech Pack High | Foldy Mirrors | TPMS | Heated Seats | Auto Hold
  7. Re: Active Info Display & Discovery Navigation (Standard)
    #17
    46 Post(s)
    Do any of you who have the standard SD Discover Nav and AID have VCDS? Just want to compare your instrument panel and 5F controller to mine, thanks.
  1. Active Info Display - where's the trip odometer?
    By mberg in forum Passat - B8 Forum - 2015 -
    Last Post: 18-09-2017, 11:23 PM
  2. Active Info display retrofit
    By MattB247 in forum Passat - B8 Forum - 2015 -
    Last Post: 09-08-2016, 04:00 PM
  3. Active Info Display
    By jimgironde in forum Passat - B8 Forum - 2015 -
    Last Post: 15-07-2016, 05:57 AM
  4. Active Info Display release
    By lozzer62 in forum Passat - B8 Forum - 2015 -
    Last Post: 04-09-2015, 09:11 PM
  5. Cotacts won't show on Discovery Navigation
    By Chaucer2468 in forum Golf MK7 - 2013 - 2019
    Last Post: 22-10-2013, 03:22 PM
