Thread: swirl flap vcd logs
Results 1 to 10 of 12
  1. Question swirl flap vcd logs
    Apr 2017
    Birmingham
    when logging on vag.com group 36 and 37 , is it requested vs actual? the field names?
    had bank 2 fault:
    004120 - Intake Manifold Runner (Bank 2)
    P1018 - 001 - Lower limit not reached
    Freeze Frame
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 260149 km
    Time Indication: 0
    Date: 2017.05.02
    Time: 14:07:16
    Freeze Frame
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Voltage: 12.54 V
    Duty Cycle: 20.5 %
    Duty Cycle: 88.8 %
    Duty Cycle: 20.5 %
    Ive did some video logging on vcd, if any one can check if anything wrong .
    idle to Fast Rev Test
    Output Test Bank 1
    Output Test Bank 2
    Thanks in advance
  2. Re: swirl flap vcd logs
    Nov 2012
    Somerset UK
    It does help if you include your year/engine/transmission in your autosignature. Am going to guess at a V6 3.0
    As you'll know the failure of these won't affect the operation of the car, I've been driving mine for almost 3yrs with 'lower limit not reached' with no side effects in either performance or economy.
    Can you just advise what you are actually trying to do? Also use the search facility as 'swirl flaps' have been done to death on here
  3. Re: swirl flap vcd logs
    Apr 2017
    Birmingham
    Sorry it's 2006 2.7 v6 automatic, I've had my swirl flap manifold rebuilt and motors replaced last year. Just I've noticed slight flat spots under low revs eg Torque curve, plus engine management light which bugs me.
    I've done alot of research but I want a second options to see the swirl flaps are opening and closing within tolerance range.
    Sent from my SM-N9005 using Tapatalk
  4. Re: swirl flap vcd logs
    Nov 2012
    Somerset UK
    Oh, OK. Mines the 3.0 and remapped to 250 so perhaps not noticed the flat spots, as to the MIL I just applied some black marker pen to dash to stop it burning a hole in my retina...it's sailed through 2 MOT's on emissions regardless.
  5. Re: swirl flap vcd logs
    Apr 2017
    Birmingham
    Part of me regret not getting 3.0 as there wouldn't been much mpg different. It still quite nippy but not as before, I'm quite picky so want it done properly unless it's mapped out, but I don't know how strong are these automatic boxes once mapped up. It flew through last mot but had no eml light.
  6. Re: swirl flap vcd logs
    Nov 2012
    Somerset UK
    No there would be, in fact with the 10% greater engine size comes a greater than 10% power increase.
    Plus even with the MIL on and both flaps out I've managed 970 miles on a single tank!
  7. Re: swirl flap vcd logs
    Jul 2013
    76 Post(s)
    Have you done the adaptation for the intake runner motor?
    Prerequisites:
    • Ignition ON
    • Engine OFF
    • System voltage at least 11.0 V.
    [Select]
    [01 - Engine]
    [Basic Settings - 04]
    Group 142
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    Wait until Field 4 shows "ADP. O.K.".
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    This may be slightly different for you engine VCDS will have it in the basic settings drop down menu.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
  8. Re: swirl flap vcd logs
    Jul 2013
    76 Post(s)
    If your not sure which side it is, run the Bank one test and watch the linkage move on the intake runner motor.
    Then run the bank 2 test and observe the linkage movement for comparision.
    You may have stripped teeth in the motor or a rose joint on the linkage is loose/worn.
    The flaps may have a build up on them in one spot stopping the full movement.
    Dan
  9. Re: swirl flap vcd logs
    Apr 2017
    Birmingham
    Hi ive tried hunting for the adaptation but cant seem to find any, just says error
  10. Re: swirl flap vcd logs
    Apr 2017
    Birmingham
    figured bank 2 is passenger side, nearest coolant bottle. when ive done the output test
    ive stripped swirl flap motor down cant seem to find any wear on the cogs or broken pieces. gave it good clean still the same. had look swirl flaps still look clean.
  1. swirl flap kits..
    By swalker in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-09-2016, 12:16 PM
  2. Swirl flap issue
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-12-2015, 10:21 AM
  3. Swirl flap dilemma
    Last Post: 27-11-2015, 02:01 PM
  4. Swirl flap repair kit
    Last Post: 13-09-2015, 02:11 PM
  5. swirl flap repair set
    By urgi in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 08-04-2013, 10:23 PM
