Thread: Lacquer Lift
  1. Lacquer Lift
    Ardfern
    8 Post(s)
    As you may guess from my question, this is not my normal area of the forum, but I am assuming that you chaps are experts on this more basic problem.
    My A4 B8 S line saloon (2008) has developed an unfortunate case of lacquer lifting on the rear bumper behind the rear wheels. I suspect that it has been encouraged by pressure washing, which I expect you all regard as a form of vandalism but which is all I have had time for.
    Is there a reasonable solution other than having the rear bumper re-painted and lacquered?
    Is this a 12 year corrosion warranty issue? I don't think it should happen even if subjected to pressure washing which is an almost ubiquitous method adopted by most motorists.
    Any constructive advice will be gratefully received.
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  2. Re: Lacquer Lift
    Pembrokeshire
    22 Post(s)
    nothing else to do other than re paint it. is this the original bumper though ? more common on replacements or even just originals that have been painted. ?
  3. Re: Lacquer Lift
    Ardfern
    8 Post(s)
    Thanks Z. I believe it is the original and don't think it has been re-painted.
    Is it worth cleaning up and removing the loose lacquer and slapping on a bit of lacquer to seal the edges and prevent further lift, I wonder.
    Being quite low down and on a car that is by no means pristine, it may not be worth the expense of a full bumper re-paint but I don't want it to spread.
    Lotus Elan SE 1991
  4. Re: Lacquer Lift
    Pembrokeshire
    22 Post(s)
    you could try..
  1. Audi A6 4F pre face lift with face lift upgrades questions ...
    By gupsterg in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-11-2013, 12:52 PM
  2. Lacquer Problem
    By Major Clanger in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-02-2013, 06:32 PM
  3. Attention Lacquer problems :(
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-04-2011, 03:59 PM
  4. Knaquered Lacquer.
    By Hex69 in forum General Detailing/Cleaning Questions
    Last Post: 02-06-2008, 11:48 AM
  5. Lacquer knackered
    By Hex69 in forum Chat - Anything with wheels
    Last Post: 04-04-2008, 08:48 PM
