Thread: HIGHWAY LIGHT FUNCTION ACTIVE (above 90MPH) - changing speed to 70mph so legal
  1. HIGHWAY LIGHT FUNCTION ACTIVE (above 90MPH) - changing speed to 70mph so legal
    Feb 2013
    Uk
    38 Post(s)
    if you select "09 Cent Elect" module , select module "2-8K0 955 559 -RLS" from the drop down menu"
    go go to Byte 0 and you will see the following options
    Bit 0 HIGHWAY LIGHT FUNCTION ACTIVE (above 140kph / 90 mph). NOTE THIS IS "UNCHECKED"
    Bit 1 RAIN LIGHT FUNCTION ACTIVE
    Bit 2 LIGHT ACTIVATION NORMAL THRESHOLD
    Bit 3 RAIN SENSOR INACTIVE (eg security/armoured glass)
    i am interested in the HIGHWAY LIGHT FUNCTION , Will the "highway light function" work with xenon headlights with DRLs,rain lights ?
    If so would it be possible drop the speed from 90mph to 70mph, so it activates whilst driving at the legal speed limit.
  2. Re: HIGHWAY LIGHT FUNCTION ACTIVE (above 90MPH) - changing speed to 70mph so legal
    46 Post(s)
    Just switch your dipped beam on, it's the same thing.
  3. Re: HIGHWAY LIGHT FUNCTION ACTIVE (above 90MPH) - changing speed to 70mph so legal
    Feb 2013
    Gloucester
    57 Post(s)
    Are you sure it's MPH and not KMPH?
    The highway light (IIRC) lifts the height of the lights on motorways. On the wife's A5 it is notable when it jumps (if you're looking for it) but she only has it as she has the adaptive lights. I have it also but have led lights. It might work but I doubt it if the hardware is missing.
    Both of ours active around 60mph
    Sent from my iPhone using Tapatalk Pro
  4. Re: HIGHWAY LIGHT FUNCTION ACTIVE (above 90MPH) - changing speed to 70mph so legal
    46 Post(s)
    Thats high beam assist.
    "Highway light" is when the car automatically puts the dipped beam on regardless of time to make you more see-able at high speed.
  5. Re: HIGHWAY LIGHT FUNCTION ACTIVE (above 90MPH) - changing speed to 70mph so legal
    Feb 2013
    Uk
    38 Post(s)
    Thanks,
    just checked the module again with VCDS , and it def says"140kph/90mph"
  6. Re: HIGHWAY LIGHT FUNCTION ACTIVE (above 90MPH) - changing speed to 70mph so legal
    46 Post(s)
    Quote Originally Posted by Q7quattro View Post
    Thanks,
    That is correct, it's aimed towards German vehicles due to high speeds.
    See my reply above.
    1 1 0
  1. Important WARNING! - Speed Cameras Active on M62
    By AGW82 in forum Chat - Anything with wheels
    Last Post: 08-10-2013, 07:25 PM
  2. ABS warning light when 70mph
    By A4Chris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-08-2008, 01:48 PM
  3. Please Help Engine jerks at highway speed
    By bad281 in forum Golf MK3 - 1993 - 1999
    Last Post: 21-06-2008, 08:08 PM
  4. 70MPH Speed Limit
    By Fettler in forum Chat - Completely Off Topic
    Last Post: 18-05-2007, 04:03 PM
  5. Your Legal Rights - All matters Legal and Associated
    By auiron in forum Chat - Completely Off Topic
    Last Post: 29-01-2007, 06:58 PM
