Thread: Parking Brake Fault
  1. Parking Brake Fault
    Feb 2015
    Peterborough
    7 Post(s)
    I have a fault with my EPB. I was doing a rear pad and disk change on my 2010 A6 following the guide on the rosstech website. As i began and set the caliper to open on VCDS my dashboard displayed a parking brake fault, is this normal? Not knowing and with the parking brake now released i continued and changed the disks and pads. I continued on with the procedure by closing the EPB and then carrying out the function test all ok. (I had battery charger hooked up throughout). I am still displaying parking brake fault on the dash and the parking brake is now not working,the light on the switch just flashes when i try to operate it. The EPB functions when controlled by VCDS. Any ideas?
    I do have a broken wheel speed sensor that I found/broke while changing the disks could this be the cause?On my way out in a minute to go pick a new one up?
    VCDS print out below
    VCDS Version: 17.1.3.0
    Data version: 20170320 DS267.7
    Ross-Tech: Home
    VIN: WAUZZZ4F8AN045799 License Plate: VN59UHO
    Mileage: 193380km-120160mi Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 03 05 08 09 0E 15 16 17 19 36 42 46 4F 52 53 55 56 5F 62
    72 76
    VIN: WAUZZZ4F8AN045799 Mileage: 193380km-120160miles
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 019 AG HW: 03L 906 022 FG
    Component: R4 2.0l TDI H03 9978
    Revision: 11H03--- Serial number:
    Coding: 010D002C18072118
    Shop #: WSC 10756 002 1048576
    ASAM Dataset: EV_ECM20TDI03L906019AG A01006
    ROD: EV_ECM20TDI03L906019AG.rod
    VCID: 70E46E9FABA293C119-8024
    1 Fault Found:
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00 [039] - -
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 4
    Mileage: 193389 km
    Date: 2017.04.27
    Time: 12:35:06
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 8 °C
    Intake air temperature: 10 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 12.220 V
    Unlearning counter according OBD: 40
    Crankshaft speed (RPM): 0.0 /min
    Vehicle speed: 0.00 km/h
    Accelerator position: 0.00 %
    Cruise Control System: specified speed: 0.00 km/h
    Cr Ctl st Sh Off Irv Lst-Bit 0: 11111111
    Cr Ctl st Sh Off Rv Lst-Bit 0: 11111111
    Cruise Control System (CCS): switch position-Bit 0: 10000001
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AK HW: 4F0 614 517 AT
    Component: ESP8 front H03 0060
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020859
    Shop #: WSC 02325 785 00200
    VCID: 6DDA77EB74907E2932-8038
    1 Fault Found:
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 145
    Mileage: 193389 km
    Time Indication: 0
    Date: 2017.04.27
    Time: 12:56:40
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0382
    Hex Value: 0x0008
    Hex Value: 0xB194
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
    Component: FBSAUDIC6 ELV H05 0100
    Revision: 00H05000 Serial number: 10602501454421
    Coding: 0000145
    Shop #: WSC 02324 785 00200
    VCID: 254A4FCBECE08669BA-8070
    Subsystem 1 - Part No: 4F0 910 132 F
    Component: FBSAUDIC6 EZS H04 0020
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0054
    No fault code found.
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 B HW: 4F2 820 043 AA
    Component: KLIMABETAETIGUNGH30 0080
    Revision: 00000074 Serial number: 00000030491522
    Coding: 0001300
    VCID: 1D3A672BC4B04EA9E2-8048
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 M HW: 4F0 907 279 A
    Component: ILM Fahrer H22 0320
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0113121
    Shop #: WSC 02335 785 00200
    VCID: 336EA1935234E8D924-8066
    Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H10 0040
    Coding: 00056595
    Shop #: WSC 02335
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
    Part No SW: 4F0 035 110 A HW: 4F0 035 110
    Component: CDC-MP3-Alp H44 0140
    Revision: AA001001
    VCID: 152A7F0BFC8016E92A-8040
    Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
    Part No SW: 4F0 910 655 Q HW: 4F0 959 655 G
    Component: Airbag AU1042 H06 0160
    Revision: -------- Serial number: 003F9001WWAG
    Coding: 30314236303630303033554A305234463053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 356A9F8B9440F6E90A-8060
    Crash sensor for side airbag: driver side:
    Serial number: 3574SRB40000A1AC91BE
    Crash sensor for side airbag: front passenger side:
    Serial number: 3584SRB40000A1A8E9BO
    Crash sensor for side airbag: rear: driver side:
    Serial number: 3516HRB402T9LBCH03QW
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 3526HRB402J9KI9J5CGW
    Crash sensor for front airbag: driver side:
    Serial number: 3554NRB4000052BC6751
    Crash sensor for front airbag: front passenger side:
    Serial number: 3564NRB4000052B0829Y
    1 Fault Found:
    12583424 - Powertrain Databus
    U0002 00 [008] - No Communications
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0530
    Revision: 00H05000 Serial number: 90055093240219
    Coding: 0112042
    VCID: 275645C396EC947988-8072
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
    Part No SW: 4F0 920 983 G HW: 4F0 920 983 G
    Component: KOMBIINSTR. H08 0144
    Revision: 00100000 Serial number: CN3035JC9
    Coding: 2F75100502002600010400
    Shop #: WSC 02391 823 56573
    VCID: 3064AE9F6322D3C159-8064
    1 Fault Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 188542 km
    Time Indication: 0
    Date: 2017.02.24
    Time: 12:14:33
    Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
    Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
    Component: GW-BEM 4CAN-M H06 0035
    Revision: LB100029 Serial number: 2900L09B080069
    Coding: 000B03
    VCID: 397293BBB0581289EE-806C
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0125
    Serial number: 00000000002790809725
    Address 36: Seat Mem. Drvr (J136) Labels: None
    Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
    Component: MEM-FS H08 0062
    Revision: AA000000 Serial number: 00001010034599
    Coding: 00781300004011110000
    VCID: 3162AB9B6828DAC956-8064
    Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
    Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
    Component: TSG FA H11 0250
    Revision: Serial number: 0000102374060
    Coding: 011F06205E41410001
    VCID: 4688E847F1A66D7193-8012
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
    Component: Komfortgeraet H29 0250
    Revision: 02500029 Serial number: 01242876580000
    Coding: 0140019
    VCID: 356A9F8B5C40F6E90A-8060
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H05 1501
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H13 0100
    Revision: Serial number: 00000000673389
    Coding: 0001104
    VCID: 5EB82027893615B1BB-800A
    Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
    Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
    Component: TSG BF H11 0250
    Revision: Serial number: 0000102392531
    VCID: 458AEF4BCCA066699A-8010
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
    Component: EPB CEFC0090 H05 0090
    Revision: --H05---
    Coding: 0000111
    Shop #: WSC 02145 785 00200
    VCID: 21425BDBF8C86A49C6-8074
    1 Fault Found:
    01316 - ABS Control Module
    008 - Implausible Signal - MIL ON
    Freeze Frame:
    Fault Status: 11101000
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 145
    Mileage: 193384 km
    Time Indication: 0
    Date: 2017.04.27
    Time: 12:35:06
    Freeze Frame:
    Voltage: 11.28 V
    Count: 231
    Address 55: Headlight Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 H
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000003
    VCID: 3F86FDA36E7C3CB9D0-806A
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4F0 035 056 B HW: 4F0 035 056
    Component: Radio U STD H45 0020
    Revision: AB001007 Serial number: 342K-097731086
    Coding: 010003020100000000
    VCID: 1F465D230EBC5CB9F0-804A
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 4E0 035 652 A HW: 4E0 035 652
    Component: B-BN-EU H52 0048
    Revision: -------- Serial number: 349K6097526774
    Coding: 010101010102C3ED41000705EF6300030001
    Subsystem 1 - Part No: 4G0 919 884 F
    Component: EUR 2010 1005
    Subsystem 2 - Part No SW: 4L0 919 604 HW: 4L0 919 604
    Component: DU6 Basic H43 0306
    Serial number: 9355KT091052454
    Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 H
    Component: Bedienteil MM H01 0060
    Serial number: 00000001452693
    Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
    Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
    Component: TSG HL H10 0251
    Revision: Serial number: 0000102389893
    Coding: 010E04204041220001
    VCID: 438EF153C2945859B4-8016
    Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
    Component: TSG HR H10 0251
    Revision: Serial number: 0000102389756
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
    Component: Parkhilfe 8-Kan H02 0500
    Revision: 00H02000 Serial number: 12630932702539
    Coding: 0200016
    VCID: 2A50BCF785FEA91197-807E
    End-------------------------(Elapsed Time: 02:52)--------------------------
    Any help would be much appreciated.
    2010 A6 TDI 170 S Line Avant
    Sold 2007 A3 TDI 170 S Line
    Sold - 2002 S3
  2. Re: Parking Brake Fault
    135 Post(s)
    2043 Post(s)
    If you replace the ABS sensor and clear the ABS code the EPB code should clear.
  3. Re: Parking Brake Fault
    Feb 2015
    Peterborough
    7 Post(s)
    Thanks for your reply mate, yeah I replaced the sensor and now the EPB works fine now. Just got an ESP fault now. Think that just needs the ESP function test doing. So after tea I will go find an empty car park and do the stupid ESP which involves driving around in circles at low speed.
    With all the horror stories around I was concerned earlier I may have fried the control module.
    Sold - 2002 S3
  4. Re: Parking Brake Fault
    135 Post(s)
    2043 Post(s)
    It can be a sketch to get the ABS ECU to complete the test, drives me to distraction sometimes. One I did a few weeks back just would not pass on VCDS so I had to use ODIS which starts to get expensive.
  1. Parking brake fault - again
    By DSGboy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-04-2016, 09:35 PM
  2. Parking Brake Fault
    By podwin in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2011, 05:06 PM
  3. Parking Brake Fault please help
    By dilun in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-01-2011, 07:39 PM
  4. Parking Brake Fault
    By dhanratty in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-11-2010, 11:41 PM
  5. Please Help Parking Brake Fault..........
    By smiggy9 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-07-2010, 11:11 AM
