Thread: Injectors
  1. Injectors
    Mar 2017
    GB
    I've trying to self sort a slow start issue with my car. It has the rattle on startup too.
    I've spent a few nights reading through gupsterg's epic threads on his audi issues and learnt how to read my injectors via vcds to see if this could be my issue.
    I'm pretty confident my injectors are fine one is possibly new? and I have a chain rattle to sort.
    Just wondered if someone would mind looking at my photos and confirm they are good strong readings please
    Sent from my LG-H815 using Tapatalk
  2. Re: Injectors
    Mar 2017
    GB
    Is there anybody here?
  3. Re: Injectors
    Jul 2008
    Lisburn
    16 Post(s)
    Maybe just outside the scope of those currently on. There is a vcds help section did you try there?
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  4. Re: Injectors
    Mar 2017
    GB
    I hadnt no I'll take a look
  5. Re: Injectors
    Sep 2011
    Lurking over a keyboard ...
    To me the data looks reasonable, I have mentioned/tagged @Crasher and he has vastly greater real experience . This post has info/another link that maybe helpful to you or another coming to your thread.
    Are you having any other issues which would point to you do suspect injectors? ie rising oil level, huge plumes of white smoke at idle, etc.
    This slow start issue. Perhaps elaborate on that. Do you go for ignition and there is delayed response of starter kicking in?
    BTW Welcome to VWAF! .
  6. Re: Injectors
    Mar 2017
    GB
    Hi Gupsterg.
    First of all let me say thanks for all the posts you have made regarding your issues I have pretty much read everything you have written and its been a huge help.
    Since buying the car I have had an issue where by its taking up to 10 seconds to start the car (first start of the day)
    There seems to be a breif pause inbthe starter mid crank like the battery is low.
    There is also a rattle for 1~2 seconds after start. But it disapears quickly.
    I also have an issue where the car runs out of fuel at 1/4 of a tank. Sender unit has been replaced in the past and all seems to work.
    As my injectors check out (thanks for confirming) I'm now on a path to sorting the top right bank tensioner.
    There is a small amount of smoke at idle when cold but only what I would call normal for a cold start.
  7. Re: Injectors
    Sep 2011
    No problem on past shares , done as much to help myself and others , with community we as owners have strength for sure .
    It maybe your starter motor has an issue. I used to have delayed start intermittently on rare occasions. I put it down to the chain rattle / suspected injectors & "system" / battery. After all that had been done, I would get it still, again very rarely. I'd turn ignition and nothing happened, then it would just kick in IIRC, but don't hold me to that as it's been a long long while.
    Ignore the rattle for now as being the issue for delayed start. I reckon calibration of sender unit may have been out when you run out of fuel at 1/4 of tank. Replacing the sender unit I would assume either recalibration was done or if not done the "settings" are right for new one (as long as all is well in that aspect).
    From how you describe smoking you are experiencing "normal" aspect, abnormal is in this thread.
    Also you can date the injectors, etc, from collar markings, so you know how old, etc.
  1. Question BMP injectors
    By Abduls Miezis in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-04-2017, 10:18 AM
  2. 2.5 TDI Injectors
    By philmax in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-07-2011, 10:02 PM
  3. Are 170 and 140 bhp injectors different?
    By mikecb1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-04-2011, 10:20 AM
  4. Question injectors
    By stevie-g-2.6 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-05-2010, 03:02 PM
  5. Injectors
    By fishersb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-02-2010, 07:05 PM
