Thread: Urgent Help - Car Cutting Out While Driving
Results 1 to 8 of 8
  1. Urgent Help - Car Cutting Out While Driving
    Jan 2010
    kent, england
    10 Post(s)
    Hi All,
    Apologies for another "urgent help" request. We have a 2005 2.0TFSI. Yesterday whilst driving it completely lost all power and cut out - there was no warning that this was going to happen and no warning lights came up on the dash. Restarted the car and it drove fine only to happen again a bit later on - no warning once again.
    The urgency is that we are due to drive from London to Dorset tomorrow for the Easter half term and I'm worried about going on the motorway. Getting it booked in and looked at at such short notice is going to be impossible - is there anything I can do/check on the car before our journey?
    Many thanks in advance
    Mike.
  2. Re: Urgent Help - Car Cutting Out While Driving
    46 Post(s)
    Ideally you need a diagnostic check first of all to see if there are any electrical issues then afterwards depending on the outcome of said diagnostic, some manual checking with a smoke tester to check for air leaks etc
    I wouldn't be driving the car if I were you, you could end up breaking down completely
  3. Re: Urgent Help - Car Cutting Out While Driving
    Jan 2010
    kent, england
    10 Post(s)
    Thanks Chris, will look into hiring a car for the week.
    I've just noticed there is oil on the drive, this is very recent. Is it an unfortunate coincidence that we also have an oil leak or can it be linked to the car cutting out?
    Thanks again
    Mike
  4. Re: Urgent Help - Car Cutting Out While Driving
    Jul 2015
    Staffs
    46 Post(s)
    Could be a fuel pump issue. Dont drive on the motorway until it's fixed.
    Ian
    A4 B6 Avant Nogaro Blue
  5. Re: Urgent Help - Car Cutting Out While Driving
    Jan 2010
    kent, england
    10 Post(s)
    Right - good news! I've got the car jacked up and the scuttle panel off. The oil leak appears to be from a loose sump plug! We've just had the car serviced, so this would make sense - although I shall be reporting this back to the garage who we have been using for years!
    Could this cause some sort of oil pressure/vacuum issue that would cause the car to cut out? Fingers crossed this is all linked and I can solve it by simply tightening the sump plug up!
    Mike.
  6. Re: Urgent Help - Car Cutting Out While Driving
    Jul 2015
    Staffs
    46 Post(s)
    I highly doubt that would cause the car to cut out unless, you ran out of oil and the engine seized.
    Ian
  7. Re: Urgent Help - Car Cutting Out While Driving
    Pembrokeshire
    22 Post(s)
    check around the top of the engine for a plug that may have been disturbed during the service, amm plug, coil packs etc... make sure everything is pushed fully into place.
  8. Re: Urgent Help - Car Cutting Out While Driving
    132 Post(s)
    1979 Post(s)
    If there end up being no codes stored, the engine speed sensor is a possibility.
  1. Question MK5 Golf cutting out while driving
    By dajackel12 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-04-2016, 04:42 PM
  2. Cutting out when driving
    By Davie77 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-02-2016, 10:11 AM
  3. Please Help A4 54 reg - Ignition cutting out while driving
    By em2010 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-09-2010, 03:53 PM
  4. Important Engine Cutting out while Driving!
    By Paulw0t in forum Golf MK4 - 1999 - 2004
    Last Post: 30-12-2008, 01:15 AM
  5. Golf 1.6 Mk4 - engine cutting out while driving...
    By hemang02 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-10-2007, 12:59 PM
