Thread: BMP injectors
  1. BMP injectors
    Aug 2016
    Liverpool
    Hi !
    So the issue is passat b6 2.0 tdi BMP when warm engine is shut down and started while still not cooled it starts badly, like starting to crank then suddenly stops turning and then starts with shudder for 2 sec. I believe its one or more injectors after engine is stopped still leak some amount of diesel in combustion chamber and when trying to start its hydrolocking until valves open.
    How its possible to test and find faulty injector/s ?
  2. Re: BMP injectors
    131 Post(s)
    1976 Post(s)
    Have you had a fault code read done? I personally feel it is not possible to correctly test these injectors, I have tried various people and had them say faulty and they prove not to be and OK when they aren't. If no fault codes come up, take off the cam cover and see what the injector part number is.
  3. Re: BMP injectors
    Aug 2016
    Liverpool
    Did code read some time ago and there was nothing, but will do it again maybe something pops up.
    You are right thats what I was told before about these injectors - they are not giving up for testing.
  4. Re: BMP injectors
    Mar 2014
    Ashford
    9 Post(s)
    I have a 2006 56 plate Passat with the same engine and there was a recall on injectors. Mine were all replaced for free. You might want to check with a local dealer to see if your car matches a recall. If it does you might just get them replaced for free. After all, injectors are not cheap!
  5. Re: BMP injectors
    Aug 2016
    Liverpool
    What would indicate diesel fuel going in to sump oil if level isnt rising, at least significantly ? When looking at oil level noticed it smells weird.
  6. Re: BMP injectors
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    You could do a basic viscosity check; get a sample of used suspect oil and same quantity of new oil, drop same ammount of oil from each sample onto a smooth inclined surface and see difference in how fast the samples run downhill. Or send a sample away for analysis, or get a set of Jungs falling spheres.
  7. Re: BMP injectors
    Aug 2016
    Liverpool
    Thanks, probably I have to warm it up a bit before the test ?
  1. New after some help injectors
    By Glynrs3737 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-01-2014, 12:14 PM
  2. Important A3 tdi 170 injectors
    By panscrub in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-08-2012, 04:05 PM
  3. 07 2.0 tdi injectors?
    By 5m4 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-12-2011, 01:37 PM
  4. tdi injectors
    By j13hna in forum Bora - 1998 - 2005
    Last Post: 02-11-2011, 09:04 PM
  5. 1.9 TD AAZ injectors
    By gkm24 in forum Golf MK3 - 1993 - 1999
    Last Post: 01-10-2008, 08:37 AM
