Thread: ASZ Timing
Results 1 to 10 of 14
  1. ASZ Timing
    Feb 2010
    East Yorkshire
    Just replacing cambelt on ASZ engine and unable to locate the cam lock I had to tipex a tab on the cam pulley. I have reassembled but just noticed this.
    The cam appears to be 30deg out.
    Should I stick to the tipex marks I put on before removal or strip the sprocket off set the cam by the locking pin and reassemble?
  2. Re: ASZ Timing
    Pembrokeshire
    22 Post(s)
    i suspect the cam pulley is on wrong, thats why you cant find the hole for the pin. i would remove the pulley and get it all done right.
  3. Re: ASZ Timing
    134 Post(s)
    2007 Post(s)
    Yes, remove the pulley, check the hub behind is aligned with the hole and refit the pulley in the correct position.
  4. Re: ASZ Timing
    Feb 2010
    East Yorkshire
    Thanks for the replies, Update - Just come in from taking the the sprocket off n setting the hub by the lock pin then refitting the sprocket and you can't turn the engine more than about 20deg before it locks. Set it all back to tipex marks and and turns full 360.
  5. Re: ASZ Timing
    134 Post(s)
    2007 Post(s)
    Odd, the hub is supposed to have a key way and the cam a slot so I can't see that being the problem, are you using a crank locking plate?
  6. Re: ASZ Timing
    Feb 2010
    East Yorkshire
    [QUOTE=Crasher - Odd, the hub is supposed to have a key way and the cam a slot so I can't see that being the problem, are you using a crank locking plate?]
    I didn't have a locking plate at the time of fitting the belt which is why I tepexed crank n cam. The engine is a replacement fitted after turbo failure destroyed the original. It revs up smooth as long as you're smooth with the throttle but has slight knock if rough so thought I'd get the locking tools as and check the timing's deffo right. which is when I've found the above issue.
  7. Re: ASZ Timing
    Dec 2007
    8 Post(s)
    Maybe no help now,but I found in my ASZ that the cam locking pin was a fraction too large to fit in locating hole,
    the drill bit was the same,so I expect the hole was a fraction smaller,I spent ages before fitting a pin that would enter
    There are also two types of crank locking tools, I think the ASZ has the round cogs,if I remember correctly.I got the wrong one first.
  8. Re: ASZ Timing
    Feb 2010
    East Yorkshire
    [QUOTE=micheal balbrig - Maybe no help now,but I found in my ASZ that the cam locking pin was a fraction too large to fit in locating hole,
    the drill bit was the same,so I expect the hole was a fraction smaller,I spent ages before fitting a pin that would enter]
    This is true, I thought it might've been the cheap locking kit but 6mm drill was too tight t get in so found 5.5 drill is better fit than 6mm lock pin
  9. Re: ASZ Timing
    134 Post(s)
    2007 Post(s)
    Are you using a locking plate now AND the correct design as there are two?
  10. Re: ASZ Timing
    Feb 2010
    East Yorkshire
    This is it, 10050 type. With it installed the tipex marks line up (but the cam lock doesn't)and engine runs have a video but can't upload it.
  1. Timing belt or timing chain?
    By nigedvd in forum A7 - S7
    Last Post: 04-11-2016, 08:45 AM
  2. Question 2.4 v6 timing kit
    By geoff.hermans in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-02-2011, 10:07 PM
  3. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  4. Question Timing Belt or Timing Chain ??
    By thomascy in forum Golf MK5 - 2004 - 2009
    Last Post: 08-09-2009, 05:22 PM
  5. Please Help 3.0 30v Timing
    By inertia in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-07-2008, 11:13 AM
