Thread: Help needed RE passenger door window, lock and wing mirror
  1. Help needed RE passenger door window, lock and wing mirror
    Jul 2016
    York, UK
    Hi all.
    My passenger door doesn't work - at all. The window does not wind down from passenger switch or drivers side switch. Central locking does not work at all on the door. And finally, I can't adjust the wing mirror from the control on the drivers door.
    Oddly enough, when I remove the wiring loom from the door and put it back in again, the window works for about 5 minutes from the passenger door, and then nothing - does not work at all again, until I remove the loom and reattach it again.
    I've pulled codes:
    Address 46**** -------------------------------------------------------
    ** Controller: 1J0 959 799 AH
    ** Component: 4U Zentral-SG Komf. 0001
    ** Coding: 04097
    ** Shop #: WSC 31414
    10 Faults Found:
    01328 - Convenience System Data Bus
    *********** 35-10 - - - Intermittent
    01334 - Door Control Module: Rear Right (J398)
    *********** 49-00 - No Communications
    01333 - Door Control Module: Rear Left (J388)
    01332 - Door Control Module: Passenger Side (J387)
    01331 - Door Control Module: Driver Side (J386)
    00931 - Locking Module for Central Locking: Rear Right (F223)
    *********** 54-00 - Incorrectly Equipped
    00930 - Locking Module for Central Locking: Rear Left (F222)
    00928 - Locking Module for Central Locking: Front Driver Side (F220)
    *********** 27-10 - Implausible Signal - Intermittent
    These codes are telling me that nothing is communicating! The rear doors lock and unlock as they should, and the windows do (intermittently) work....
    Please all - help is seriously needed. Going mad!
  2. Re: Help needed RE passenger door window, lock and wing mirror
    Jul 2007
    glasgow
    35 Post(s)
    likely broken wire (s)
    can you get one from a scrapyard to test ?
    Maybe who ever uses the door has continually stretched the wires by fully extending the door to get out, then the wires are just slightly pulled out of the connecting block; sometimes you can get a wee screwdriver in & push the wires back into place .................. other times they use pop back out ................ like your experiencing
    I would go for a broken wire and trying one out of a scrapyard
  1. Replies: 1
    Last Post: 28-01-2014, 11:51 AM
  2. Weird one inverted window button passenger door after mirror dip try.
    By A6-MO in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2013, 10:04 AM
  3. water leak from top of passenger door(wing mirror)
    By justin31 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2009, 12:04 AM
  4. Replies: 1
    Last Post: 25-05-2009, 10:52 AM
  5. Help! No passenger door lock or mirror control!
    By macdaddy in forum Golf MK5 - 2004 - 2009
    Last Post: 11-02-2009, 06:59 PM
