Thread: door speakers
Results 1 to 10 of 15
Hybrid View
  1. Exclamation door speakers
    i have a mk 4 golf tdi and i am looking at upgrading the speakers, on the doors.
    on the front
    firstly what size are the standard speakers?
    and secondly if i buy adaptor plates such as these : http://caraudiosecurity.com/shop/product/products_id/2005.html
    will the door cards fit back on and will modification need to be done?
    on the back
    there are no speakers installed in the back doors just wundering if the speaker connectors will still be there?
    there are grills already there just no speakers,
    what size speakers are ment to be there?
    will the same adaptor plates as above fit the back
    thanks,
    Spinks
  2. Re: door speakers
    Jul 2007
    right the front is 6.5 am sure it is, as for the adaptor plates a dont think you will need them. the back a think is 6.5 as well. yeah the connecters etc will be there as well only reason ano is because a was tryin 2 run my 6x9s off them coz ma amp wasnt powerful enuff.
    as for door speakers what kind you goin for ?
  3. Re: door speakers
    7 Post(s)
    Believe it or not, the stock speakers are quite good and can handle a fair bit of power if driven with a clean signal.
    I'd turn my attention to amping them first / instead.
  4. Re: door speakers
    i dont know what speakers im looking foor but im off to USA tomoro and there much cheaper over there. is there any you would recomend, i will have internet connection whilst in USA so will be checking up every day for replys
    thanks
    spinks7
  5. Re: door speakers
    helo there i have just joined as i was lookin at a few of these forums!
    i am also considering doing the same to my mark 4 golf 1.6s 2001
    dont no if this is any help but i found these speakers http://www.caraudiocentre.co.uk/prod...7i_p-22421.htm
    they are quite expensive but are the most powerful i have found.
    hope that helps
  6. Re: door speakers
    Jul 2007
    dont waste your money on them mate trust me if you want power go for these
    http://caraudiosecurity.com/shop/pro...s_id/5769.html
    they maybe me 30/40 pounds dear but it will be worth every penny.
    looks @ the Figures:
    Infinity door speakers - 2-75 RMS/225 peak power.
    Alpine Type R door speakers 110 RMS/330 peak power.
    I Have Just Got A Alpine Type S Sub & Its Only 300rms/900 peak But Its The Quality, Etc You Are Paying For, Dont Buy JBL Spl Etc Cause There All Crap. For Another £30 You Can Buy Alot Better Then Again There Is Alot Better Than Alpine As Well I.e rainbow Etc & There About 200+ For Door Speakers Alone.
    Basicly If You Want A Good Sound System Commin In @ Entry Level A Would Say Alpine Is The Way To Go Maybe A Little Dearer But WORTH IT!
  7. Re: door speakers
    i was looking at speakers like that but wasnt sure wat the small box was for?
    also i have a 10 inch alpine type R sub in ther old style 1 with a 800w pioneer amp hooked up to 2 infinity 6x9s, but i am tihnkin of upgrading my sub to a 12'' but not sure wether to get 1 or 2 subs?
    write bak asap
  8. Re: door speakers
    Jul 2007
    Thats What You Wire Everything Into Then Run It Into Your Amp Am Sure.
    Personally A Would Scrap Your Old System The Lot Of It Even The 6x9s.
    Type R Sub : £100 Or Less
    Type S Sub: £80 ish (i perfer the type s to the type r but thats just me)
    Alpine Mono Amp: £100
    Type R Door Seakers: £110
    Alpine Two Channel Amp £70
    All In Well Under £400 And A Bet Its The Best Few Hunner Quid You Have Spend In A While. As I Dont Know How Much Your Budget Is, A Dont Know If Thats To Dear For You Or Not. But TRUST ME It Takes Time & In The End You Will Thank Yourself For Savin Up For Gettin A System Like This Just get Bit By Bit Thats What Am Doin.
    As For Getting 2 Amps Its A Defos !! If You Ever Run 6x9s/door speakers Your Are Better Getting A Two Channel Amp Rather Than Getting A Big 5 Channel Amp. Puts To Much Power Throught The Amp.
    As For Two Subs, A Would Run One Sub, Break It In Get Your Door Speakers Etc Then Ask Your Self If You Want More Bass.If You Do Either Go Big Bucks & Get A Type X Or Go For Another 12 inch sub
    Hope Ave Helped You Out A Bit
  9. Re: door speakers
    Bolton
    JUST GOT SOME NEW DOOR SPEAKERS FOR MY GOLF, AND AM STRUGLING TO GET THE DOOR CARDS OFF, DONT WANT TO BREAK ANYTHING YOU SEE! ANY INFO WILL BE GREAT THNKS OH AND WILL 5-1/4" FIT OK OR ARE THEY TO SMALL
  1. t5 door speakers
    By jonicholl in forum The Commercial Range
    Last Post: 08-04-2008, 10:18 PM
  2. Most expensive rear door speakers?
    By brianf in forum Touran - Sharan - Caravelle
    Last Post: 23-08-2007, 10:51 PM
  3. 97 avant door speakers?
    By quattro kev in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-05-2007, 08:37 PM
  4. golf plus door speakers
    By rlambert in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-04-2007, 12:17 PM
  5. Door Speakers - Help!
    By Maddoggaz in forum 80 - 90
    Last Post: 20-01-2006, 02:19 PM
