Thread: Passenger Seat Memory Buttons Retrofit
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
  1. Passenger Seat Memory Buttons Retrofit
    Mar 2010
    37 Post(s)
    228 Post(s)
    Did this today at last...
    Before
    Finished and ready to go back into car.
    Install pics
    Bit of coding and done.
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
    0 4 0
  2. Re: Passenger Seat Memory Buttons Retrofit
    Mar 2016
    Budapest, Hungary
    39 Post(s)
    Andy,
    Great! By the way any tip to take off and install door card, as I am plannig to do it next week?
    Cheers,
  3. Re: Passenger Seat Memory Buttons Retrofit
    Mar 2016
    Ipswich
    72 Post(s)
    Quote Originally Posted by anemeth View Post
    Andy,
    Cheers,
    yeah you have to remove the grey trim first from the trim around the door handle
    you have to remove the front end first as the back part slots in
    then remove the 4 screws I think from behind the removed grey trim
    then there is a screw just under the door arm rest
    use a plastic tool and slide in the bottom corner by the speaker and carefully pull
    be carful though as one thing I've noticed is the trim lugs are very brittle
    there is also a you tube clip on removing the door card
    ANDY
    great work as alway and a pleasure to watch and see your work
    and great that you always take the time to help and give tips
    keep up the great work mate
    M
  4. Re: Passenger Seat Memory Buttons Retrofit
    Mar 2016
    KEnt
    22 Post(s)
    Congrats Andy, think your building your way up to a fully optioned q7
  5. Re: Passenger Seat Memory Buttons Retrofit
    Mar 2016
    Ipswich
    72 Post(s)
    Quote Originally Posted by Papereyes View Post
    Andy
    just don't go selling it once you have finished it
  6. Re: Passenger Seat Memory Buttons Retrofit
    Apr 2012
    Brisbane, Australia
    8 Post(s)
    Hi Andy,
    Nice work, i have been following your retrofits and will embark on door closing and maybe nightvision at some point. i have a question about passenger memory buttons. did you have any problems with the seat frames with memory function? is this a concern or did you just get lucky with the correct part numbers - i am confused in etka and see that some have memory and others don't. any insight would be great
    Regards,
    Jeremy
  7. Re: Passenger Seat Memory Buttons Retrofit
    Mar 2010
    37 Post(s)
    228 Post(s)
    Hi Jeremy. No problem. If you have electric front seats then you have everything. The buttons are literally all you need plus coding to tell the seat module its memory enabled. There is no change to the actual seat itself or frame (like previously)
    Hth
    Andy
    Sent from my SM-G928F using Tapatalk
  8. Re: Passenger Seat Memory Buttons Retrofit
    Apr 2012
    Brisbane, Australia
    8 Post(s)
    Hi Mate, that is awesome. I have electric front seats so all good. I have door cards coming from germany right now as part of the b&o kit that i have ordered, hopefully the drivers door card will have the correct facia to enable me to swao out so all i need are buttons and some wires - i have an entire car loom from q7 with b&o and 4 door looms from donor b&o car so i should have enough wires and pins to add the buttons.
    Thanks again.
    Jeremy
    Quote Originally Posted by andyhud007 View Post
    Hth
    Andy
  9. Re: Passenger Seat Memory Buttons Retrofit
    May 2017
    Reading, UK
    23 Post(s)
    Hth
    Andy
    Good work Andy. I have found the part number for the button, but do you happen to know the part number for the door panel fascia?
    I have the drivers side memory but would be good to let SWMBO have it too.
    Also, is the wiring already present in the door?
  10. Re: Passenger Seat Memory Buttons Retrofit
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by ahin4114 View Post
    Ahin
    Depends what trim colour / level you have to determine part number. What do you have?
    Wiring is not present no. As a general rule of thumb no wiring is ever present for anything that didn't come with car from factory. It must all be added.
    In the case of this one, it's 5 wires.
    Andy
  1. How to retrofit memory seat module and switch
    By Spud312r in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 11-10-2017, 10:45 AM
  2. Adjustment of Passenger seat via Drivers Seat buttons
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 12-03-2017, 01:25 PM
  3. Memory Seat Module for passenger
    Last Post: 18-01-2017, 09:37 PM
  4. Passenger Memory Seat option (seems rare?)
    By CaseyJay in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 20-05-2015, 08:53 PM
  5. Please Help retrofit comfort and memory seat
    By aristidis in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-09-2010, 05:23 AM
