Thread: Misfire - Fault Codes
  1. Misfire - Fault Codes
    Jan 2016
    North West UK
    Hi all,
    Massive vibration even when idle.
    Fault codes are as follows:
    18074 - PD Unit Injector Cylinder 1 (N240) Electrical Malfunction - P1666
    17668 - PD Unit Injector Cylinder 1 (N240) Implausible Signal - P1260
    16885 - Cylinder 1 Misfire Detected - P0301
    Naturally, need to get this sorted asap. Any experience of this? Am I looking at just a straight injector swap or loom replacement?
    Any ideas where I can get this done around Warrington / Widnes / St. Helens / Liverpool?
    Thanks In Advance
  2. Re: Misfire - Fault Codes
    Oct 2015
    GB
    Start by checking the connector plug and wires.
  3. Re: Misfire - Fault Codes
    Jan 2016
    North West UK
    Quick head under the bonnet job to check all is tight?
  4. Misfire - Fault Codes
    Oct 2015
    GB
    Quote Originally Posted by DannyBoyGolf View Post
    Yes, or check cylinder 1 connector for voltage and resistance using a multimeter
  5. Re: Misfire - Fault Codes
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    cheaper to change the loom before an injector and no point fitting a new injector into a suspect old loom.
    Darkside Developments - Genuine VW PD Injector Wiring Loom for VW 1.9 & 2.0 8v Engines
  6. Re: Misfire - Fault Codes
    Pembrokeshire
    22 Post(s)
    yep, new injector loom..
  1. A4 B7 Fault codes for misfire - coil pack related?
    By Naseem in forum VCDS - Help Requests
    Last Post: 01-08-2011, 10:59 AM
  2. Question engine misfire but no fault codes
    By waynelivesey in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-04-2011, 03:16 PM
  3. 99 A6 Avant 4.2 - misfire but no fault codes
    By sparkyjf in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-08-2010, 08:20 PM
  4. Please Help 1.8t misfire no fault codes
    By aggiss in forum Golf MK4 - 1999 - 2004
    Last Post: 09-10-2008, 10:40 AM
  5. Golf 4 misfire with no fault codes
    By kalahari in forum Golf MK4 - 1999 - 2004
    Last Post: 04-03-2008, 08:44 PM
