Thread: USB ports under arm-rest - what power?
Results 1 to 9 of 9
  1. USB ports under arm-rest - what power?
    Mar 2008
    11 Post(s)
    And Q3 for the A7 although this applied to the A6 too...
    I think the USB ports under the arm-rest are very under powered. Anyone know what they actually give out?
    I'm trying to find a reliable android app that can measure vs other USB chargers I have to see if its the ports or cable or both but if anyone knows already....
    Audi A7 Black Edition 3.0 TDI (272) 2015 (FL)
  2. Re: USB ports under arm-rest - what power?
    Dec 2012
    Birmingham, England
    Your lucky, I don't even have any USB ports under my armrest, well not that I have found anyway.
    I just have the AMI port - I bought a genuine AMI to lightning lead, but it takes an age to charge the iPhone 7.
    Also got an AMI to USB lead as part of the pack, I'll give that a try tomorrow.
  3. Re: USB ports under arm-rest - what power?
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    I don't think the Ami port gives enough power to charge modern smart phones quickly for that I use a charger from one of the cigarette lighter sockets. I'm going to hardwire some USB charging ports into the glove box our of the way for the stuff I use in the car
    Sent from my Pixel using Tapatalk
  4. Re: USB ports under arm-rest - what power?
    Jan 2017
    Leicestershire, UK
    The under-arm ones are not "intelligent" quick charging ports.
  5. Re: USB ports under arm-rest - what power?
    Aug 2015
    West Mids
    7 Post(s)
    i too don't have built in usb's I bought an Aukey dual flush usb for the cigarette with a couple of coiled usb/micro usb cables, charges very fast
    Audi A7 (2012), Black Edition 245 PS Tiptronic, Phantom Black
  6. Re: USB ports under arm-rest - what power?
    Mar 2008
    11 Post(s)
    Thanks for that - I ended up also getting the Aukey USB charger from Amazon "AUKEY Quick Charge 3.0 Car Charger 34.5W Dual Port for iPhone, LG, HTC, Nexus and more"
    This has made a HUGE difference to the point that not only does it keep the phone on the charge it was on but actually does charge the phone to 100% while running apps such as Waze/Google Maps/Spotify etc. I've never had this happen since I started with Audi that had a USB port whether it's like the A6/A7 now under the arm-rest or via the AMI in the glovebox or otherwise so this is great.
    I did do a comparison using Ampere app and there was a noticable drop in charge/current when compared to the Aukey so clearly the larger screen and higher power S7 Edge coupled with high resource apps such as sat nav works very well with the Aukey
  7. Re: USB ports under arm-rest - what power?
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    i just added an Aukey USB charger in one of the cigarette lighter ports. Im not sure why there is a need for 3 in an a7 but im using one now for my Audi connect retrofit equipment, also charges my Pixel rapidly at full speed
  8. Re: USB ports under arm-rest - what power?
    Aug 2015
    West Mids
    7 Post(s)
    you have 3 cigarette/12v points? I only have a 12v under the arm rest and another in the rear I think
  9. Re: USB ports under arm-rest - what power?
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    One in the ashtray, one under the arm rest, one under the rear AC vents and also one in the boot. Plenty of charging ports for all occupants when coupled with dual USB low profile chargers
  1. Hardwire dash mounted USB ports into fusebox - 2013 Q7?
    By Dave_Glasgow in forum In Car Entertainment
    Last Post: 22-05-2014, 01:53 PM
  2. 12v Power in arm rest
    By bigslope in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-10-2013, 09:14 PM
  3. A3 Arm rest
    By iankeay in forum Body Work, Body Styling and Body Kits
    Last Post: 31-10-2011, 03:49 PM
  4. Question Power to arm rest
    By kimbie in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-07-2011, 07:46 PM
  5. Question Arm Rest
    By bigbadsexy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-01-2009, 12:00 PM
