Thread: headlight cornering lighting
  1. headlight cornering lighting
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    I thought my xenon headlights came with the adaptive cornering function(turn left and right as you steer around bends) but it seems like i only have headlight beam assist. When i had my headlights out upgrading the xenon bulbs i noticed there was a third space for another module which i think is for adaptive corner function. I wonder can you simply add and code the modules to get this feature working. Its part number 4G8941329 which is part number 17 in the diagram
    http://www.realoem.me/Audi/RDW/A7/20.../941/941005#17
    I might see can i get a set of modules on ebay and fit them up and see what happens
  2. Re: headlight cornering lighting
    Feb 2013
    Gloucester
    57 Post(s)
    As long as the motors are in the light to move them left and right it theoretically should work. Might be worth a shot if the pets are cheap
    Sent from my iPhone using Tapatalk Pro
    Audi A7, S-line, 313 PS BiTDI Tiptronic, Daytona Grey, heated front and rear seats, Audi connect, quad zone climate control, ski chute and bag, Rear tints, 75 Litre fuel tank, All LED headlights, Night vision assistant, Rear view camera with corner view, Navigation plus, MMI touch, Heads up display, Adaptive Cruise control, Blind spot monitoring and active lane assist. Audi A5 (wifes) My Kit car blog - http://mitchsgbszero.blogspot.co.uk
  3. Re: headlight cornering lighting
    Apr 2016
    Godstone
    I don't have cornering headlights either but I coded my car to do this with the all weather lights (I think that's what there called) and this works just as well an my previous car that did have them. I'm sure it's in the VCDS sticky.
  4. Re: headlight cornering lighting
    Feb 2016
    Hungary
    116 Post(s)
    Quote Originally Posted by Goodeone View Post
    It is called "kerb light", and you are right, it can be coded and the trick can be found in the C7 Tips&Tricks topic
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  5. Re: headlight cornering lighting
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    Yes I'm aware u can code the all weather light to come on when turning at low speeds. It's the motorised left and right movement of the main bulbs I was referring to
    Sent from my Pixel using Tapatalk
  1. ambient lighting vs lighting package
    By robbyg in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 15-09-2015, 04:47 PM
  2. Replies: 8
    Last Post: 10-09-2014, 12:39 AM
  3. Question HID Kit... Only 1 headlight lighting up????
    By okam in forum Golf MK5 - 2004 - 2009
    Last Post: 13-11-2012, 04:47 PM
  4. Question boot lighting, number plate lighting faults
    By Anchco in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-05-2012, 11:34 AM
  5. Please Help Unstable when cornering
    By Singlespeed in forum Audi A3 - Archive Topics
    Last Post: 13-07-2008, 11:36 PM
