Thread: Bit of help guys..
  1. Bit of help guys..
    Oct 2015
    Enfield
    Just bought myself a 2003 A3 8L 1.8T with only 53k on the clock and a one owner car. After doing a scan with vagcom I get this error code:
    So I have replaced the temp sensor and it seems the temp gauge is still behaving the same. But I know the car is getting up to temp as the fans kick in. But after a 20 min drive to work surely the gauge should be reading 90 which is half way.
    Could this be a thermostat issue or anything I may have missed?
  2. Re: Bit of help guys..
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Use measuring blocks to check and log coolant temperature, does that P1602 keep coming back when cleared? see RossTech Wiki for P1296
    http://wiki.ross-tech.com/wiki/index...4/P1296/004758
  3. Re: Bit of help guys..
    Oct 2015
    Enfield
    Quote Originally Posted by Rob69 View Post
    17704/P1296/004758 - Ross-Tech Wiki
    Tbh I haven't cleared and re scanned since temp sensor changed.
  4. Re: Bit of help guys..
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    If its anything like my previous B5 A4, there is a sensor for ECU coolant temp, and one for the Inst.Cluster. Maybe worth a look, they are usually mounted side by side.
    Alan.
    VW T6 150 DSG Camper £££
  1. Bit It...
    By aks1989 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-03-2015, 04:34 PM
  2. Help - need a bit of help
    By b__007 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-04-2014, 04:17 PM
  3. Audi TT 2011 LED DRL Byte 24 bit 0-6 & bit 7
    By Ivor Bigun in forum VCDS - Help Requests
    Last Post: 15-03-2011, 06:42 PM
  4. needs a little bit of help
    By vwgolfmk3 in forum New Member Introductions
    Last Post: 29-03-2010, 11:50 AM
  5. A little bit about me
    By 1551 in forum New Member Introductions
    Last Post: 12-03-2010, 06:55 PM
