Thread: Oil for high mileage
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. Re: Oil for high mileage
    #21
    Aug 2015
    Northampton
    Thanks that's great, yes I will stick to this plan.
    yes mine is BVN thanks.
  2. Re: Oil for high mileage
    #22
    May 2012
    Everywhere
    308 Post(s)
    I'm definitely no mechanic I just researched oil for more than 5 minutes , lol .
    It's a confusing maze at first , total bamboozle stuff , then the penny drops and it all clicks in and makes sense .
    So as one would expect the A8 4.2 tdi to have a dpf , is this a PD or CR engine ?
    Irrespective the two Quantum ( VW owned ) oils 505.01 5W40 and 507.00 5W30 don't have that units of viscosity difference to negate a consumption difference .
    Other makes of 505.01 5W40 are slightly thicker but as before 505.01 is a step back in quality and not VW DPF friendly according to Quantum anyway .
    As 5W40 505.01 is a step back in quality , the way forward if you have a dpf thus require a C3 and suffer oil consumption issues is to up from high quality to an even higher quality niche product with better thermal stability...
    Fuchs Titan Race Pro C3 5W30 ( not a LongLife oil, change annually ) , it will contain more top group 5 Ester oil basestock .
    Group 5 -
    Group V base oils are classified as all other base oils, including silicone, phosphate ester, polyalkylene glycol (PAG), polyolester, biolubes, etc. These base oils are at times mixed with other base stocks to enhance the oil’s properties. An example would be a PAO-based compressor oil that is mixed with a polyolester. Esters are common Group V base oils used in different lubricant formulations to improve the properties of the existing base oil. Ester oils can take more abuse at higher temperatures and will provide superior detergency compared to a PAO synthetic base oil, which in turn increases the hours of use .
  3. Re: Oil for high mileage
    #23
    Oct 2015
    GB
    Very interesting gaz and thanks for the insight
    Yes the 4.2 is a cr engine mate.
  1. Question Which Oil? High Mileage 2.0tdi BKP
    By RuthlessGK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-07-2016, 10:45 PM
  2. Please Help high mileage oil filter for vw bora diesel
    By solvino in forum Bora - 1998 - 2005
    Last Post: 15-08-2014, 02:10 PM
  3. Question Recommended Oil for High Mileage 1.9td.
    By bardass in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2009, 12:18 PM
  4. Castrol GTX High Mileage oil 15w-40
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-03-2008, 12:09 AM
  5. High Mileage Diesel Oil, Passat TDi
    Last Post: 25-02-2008, 09:47 AM
