Thread: Possible tappet noise
  1. Possible tappet noise
    London
    https://youtu.be/lJvqDRTKrLo
    I bought this 3 year old Mk7 1.4l TSI Blue Motion with 15,000 miles on the clock. I don't know what's normal but the engine sound s very "tappety" to me.
  2. Re: Possible tappet noise
    Dec 2014
    Bedford
    42 Post(s)
    Sounds quite loud. Hard to say why exactly . I do know the inlet camshaft pulley fails on these engines and then the engine is ruined. I would get it checked out.
    Sent from my SM-G900F using Tapatalk
  3. Re: Possible tappet noise
    London
    Thank you, I'll get it checked out. VCDS shows no faults.
  4. Re: Possible tappet noise
    Pembrokeshire
    22 Post(s)
    too fast to be a tappet, sounds more like a chain...
  5. Re: Possible tappet noise
    Jul 2007
    glasgow
    35 Post(s)
    engine flush and change the oil filter at same time
    sounds like a diesel
  6. Re: Possible tappet noise
    London
    Thanks guys,
    I changed the oil with the fully synthetic VW recommended 504.00 Oil a few months ago at 12,000 miles. I also changed the oil filter. Because I could only replace the filter after removing the plastic (under engine) road shield anyway, I also drained the oil by removing the drain plug, instead of using a PETA or pump oil extraction system
    Anway, yesterday I took the Golf to a local independent mechanic, who I've trusted for many years. He suggests the noise is probably a soon-to-fail pulley on one of the units driven by the serpentne / fan belt. Specifically he suspects the alternator. He said "these VW engines are known for failing alternator pulleys" - oh really - I never heard that.
    He said he removed the belt and spun the altrenator pulley by hand. This often shows the fault up, he said. But it didn't in my case. He didn't charge me anything.
    I'm dubious because I think the engine nosie sounds more like a diesel than a 1.4 petrol.
    Could a failing pulley noise be that bad, I wonder.
  1. Passat 18t intermittant tappet noise
    By nickpassat1.8t in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-06-2010, 07:25 PM
  2. Strange tappet noise??????
    By balmer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-03-2010, 02:09 AM
  3. Please Help 1.6 fsi tappet noise
    By kieraz in forum Golf MK5 - 2004 - 2009
    Last Post: 18-06-2009, 08:12 PM
  4. cambelt squeak/tappet noise
    By ritter1 in forum Golf MK3 - 1993 - 1999
    Last Post: 27-01-2009, 04:58 PM
  5. AUDI 80 K reg tappet noise!!!
    By jimmyhvac in forum 80 - 90
    Last Post: 17-02-2008, 06:38 PM
