Thread: Can a lambda sensor be faulty with no codes showing?
Results 1 to 10 of 15
  1. Can a lambda sensor be faulty with no codes showing?
    Mar 2014
    midlands
    Polo failed the mot today on carbon monoxide levels (2002 1.4 16v)
    mot place said likely to be lambda sensor but the only thing that comes up with vagcom is egr insufficient flow.
    not got £140 to throw away on the possibility of it being what they said.
    anyone any ideas?
    the eml has been on for about a year, full head recondition last year due to exhaust valves, no noticeable change to performance or mpg
    thanks,
    steve
  2. Re: Can a lambda sensor be faulty with no codes showing?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    How do they know it is an O2 sensor- Did they do a scan on it or just what the MOT tester said it might be? If you're getting an EGR fault then check the EGR valve for operation. If it was all stripped down for the head job was it set up in adaptations when it was refitted, I'm thinking it's the electric actuated EGR on that engine?
  3. Re: Can a lambda sensor be faulty with no codes showing?
    Mar 2014
    midlands
    Thanks for the reply, really appreciated. Thats just their idea of what to try first so Im not convinced as theres no codes to back it up.
    I read the codes when I got it back.
    The egr fault has been around off and on for the last 3 years (got the car off a mate last year) and has been ok at mots inc the one after the head was done. Ive got the rosstech full version of the diagnostics, but I inherited it off a mate who passed away so reading the codes and clearing them is about as far as Ive got with it. Pretty sure you are right about the electric version. Can that be cleaned out?
    Something that I came across whilst browsing - some people have mentioned emissions failing because of a hole in the exhaust affecting the sensor. Can detect a bit of a blow from somewhere near the front, so will have a look in a bit. Thanks
    ps i doubt it was set up after the head was done as i dont think the guy who did it has the software
  4. Re: Can a lambda sensor be faulty with no codes showing?
    Nov 2010
    104 Post(s)
  5. Re: Can a lambda sensor be faulty with no codes showing?
    Mar 2014
    midlands
    Had a look, bit of a leak from the overlapped joining section just behind the cat & sensor so have sealed that.
    had a look at the egr and its been blanked off where the pipe goes in towards the back of the engine, going to take the blank out and see if I can get the code to go away. Thanks for the link but I think thats a bit beyond me ( give me a nice simple mk2 gti anyday). Cheers
  6. Re: Can a lambda sensor be faulty with no codes showing?
    Pembrokeshire
    22 Post(s)
    i would elave the blank in there, its been fine like it for ages, get it through the mot first. have you got the print out of the readings from the gas test. could be a leak, that can allow frsh air into the exhaust and over the lambda, which then thinks the car is running lean so bungs in more fuel to compensate. but the best way to tell is to see the readings.
    1 1 0
  7. Re: Can a lambda sensor be faulty with no codes showing?
    Mar 2014
    midlands
    Thanks, will dig them out after work
  8. Re: Can a lambda sensor be faulty with no codes showing?
    Mar 2014
    midlands
    Ah, no readings available. Fail sheet says:
    exhaust emissions carbon monoxide content at idle excessive (7.3.d.4)
    exhaust emissions carbon monoxide content after second fast idle excessive (ssame code)
    exhaust emissions lambda reading after second fast idle outside specified limits
  9. Re: Can a lambda sensor be faulty with no codes showing?
    Pembrokeshire
    22 Post(s)
    need the the readings to diagnose, impossible otherwise. they binned it instead of giving it to you, should get them to test it again and get the printout. worth sticking a can of injector cleaner in it and driving the nuts off it, test it while its nice n hot, might pass. never know...
  10. Re: Can a lambda sensor be faulty with no codes showing?
    Mar 2014
    midlands
    Been back readings are:
    0.447 co (fail)
    180 hc ok
    0.999 (some symbol)
    no error codes showing on vcds
    need to try and get it sorted this afternoon.
    any ideas? Thanks
    did notice the backbox was a bit hanging, but no holes/passed mot
  1. Telephone module faulty - codes now showing up
    By Brycie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-12-2016, 07:10 PM
  2. Question Faulty lambda probe?
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-07-2010, 08:41 PM
  3. Question Lambda Sensor fault codes.
    By robetere in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-08-2009, 06:53 PM
  4. Please Help Faulty lambda sensor
    By summerslife in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-04-2009, 10:57 PM
  5. Please Help MIL Warning Codes - faulty sensor?
    By Andrew Pawsey in forum Ibiza - Cordoba
    Last Post: 08-05-2008, 09:06 PM
