Thread: A4 2.0 TFSI Consistent hard starting
  1. A4 2.0 TFSI Consistent hard starting
    Feb 2017
    Bristol
    I've just joined up having bought an A4 TFSI.
    I've been looking around forums and can only find hard starting problems reported where the problem gets less when the car has been running.
    With mine, it is consistently the same amount of time to start, just a few seconds longer than on the button. It's been like this since I bought it so I've never known it to be different. I suspect this is the reason why my Stop Start is not working?
    Has anyone else experienced this?
    Sorry if this is something obvious or I've missed a relevant blog post!
    Any advice appreciated!
  2. Re: A4 2.0 TFSI Consistent hard starting
    Jul 2007
    glasgow
    35 Post(s)
    good starting point would be a free check on the battery
    just google free battery check in your local area
    You are looking for a dud cell(s) which means the battery is not holding its charge, sometimes a dud cell alone isn't enough to stop the car starting depending how damaged the cell is
    You have enabled Stop/ Start ......................... not switched it off by accident
    Also is if you have say the rear demister on, the stop/start wont work as the car thinks the battery wont start with heavy load
  3. Re: A4 2.0 TFSI Consistent hard starting
    Feb 2017
    Bristol
    Thanks Niall,
    I've had the battery tested at Halfords (Which they really struggled with!) But they said it's all in good health!
    The start stop didn't work when I bought it. I didn't realise it had it until I turned off the switch and back on again, and it said it couldn't switch on because of a fault. That's when I realised the slow start probably isn't quite right!
  4. Re: A4 2.0 TFSI Consistent hard starting
    Jul 2007
    glasgow
    35 Post(s)
    you will need to get it scanned to find out whats wrong with a code fault
  1. Vw v6 tdi hard starting after standing
    By stuartmvw225 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 03-11-2015, 11:11 PM
  2. 1.9 TDi Hard Starting/cutting out
    By sambofuentes in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-07-2015, 02:05 PM
  3. A4 1.9tdi avf hard starting
    By Highlandreid in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-12-2011, 01:44 PM
  4. Throttle power not consistent
    By jcousen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-11-2009, 07:02 PM
  5. Immobiliser and hard starting. HELP!!
    By Darren VWPassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-06-2007, 02:19 PM
