Thread: only drivers door opens rest are dead locked how do i open them without damaging them
  1. Question only drivers door opens rest are dead locked how do i open them without damaging them
    Feb 2017
    Manchester
    im breaking an 2005 a6 c5 avant and i need to get the other doors open but they wont open from the fob or the inside any ideas as i dont want to really damage the door cards TIA
  2. Re: only drivers door opens rest are dead locked how do i open them without damaging them
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    It sounds like the central convenience unit (under the passenger footwell carpet) is dead.
    Are all fuses ok? Try removing the unit and check for water ingress.
    If it's still not responding, you could get a wiring diagram, and can work out which cables feed the deadlock motors, and power them up directly from a battery. If the loom is broken, then this can also be done by cutting a hole in the door card and finding the cables going to the locks and powering them up.
    Without the deadlocks opened, I think serious damage is needed to open the doors!
  3. Re: only drivers door opens rest are dead locked how do i open them without damaging them
    Ayrshire, Scotland
    18 Post(s)
    If the key fob doesn't work it may need a new battery and or matching to the car.
    Does the spare work?
    If you start the car do the rear doors then open via the inside handle?
    I just had this last week when both my keys died, I had to fit new batteries and then match them to the car again before they would work.
    I'm suspicious something wiped them both within a week or do of each other.
    Best regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  1. Question central locking only opens drivers door??
    By domaldinio in forum Golf MK4 - 1999 - 2004
    Last Post: 29-08-2017, 06:51 PM
  2. Passenger door (LHD) locked/dead?
    By kristofferS in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-02-2014, 07:58 PM
  3. Passat B6 drivers door intermittently opens
    By k114l3d in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-08-2012, 10:38 AM
  4. battery change opens locked door
    By andy j 1169 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-12-2010, 09:44 AM
  5. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
