Thread: Water in the rear pasenger footwell?
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. Question Water in the rear pasenger footwell?
    May 2007
    Hi All
    I have a 2001 Passat estate, 1.9 TDi 130. About 2 weeks ago I noticed a couple of inches of water sloshing about in the rear passenger footwell. I assumed something must have been leaking, like a door seal, but they are all fine. I emptied the water and am now left with damp carpet to try and dry out.
    It appears that as I soak up the water and leave it damp for natural drying, the next day there is a bit more water there. Does any one have any ideas where this might by coming from? Is it anything to do with the two rear facing "tubes" under the front passenger seat? Is this part of the heating/cooling system?
    Any suggestions would be most welcome!
  2. Re: Water in the rear pasenger footwell?
    go here my friend, ive had the same issue, and there are lots of topics on this forum about it, follow the link to here about what i did and a link to a step by step guide to rectify the problem good luck!
    steve
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=13522
  3. Re: Water in the rear pasenger footwell?
    May 2007
    Thanks Steve but this link goes to alarm problems?
  4. Re: Water in the rear pasenger footwell?
    the water in the foot wells if left will cause all sorts of electrical issues including alarm problems,
    you will find people discussing there issues with water in the cars on that link and find another link, showing a step by step guide to curing the leak, it stems from the engine bay believe it or not,
  5. Re: Water in the rear pasenger footwell?
    Mar 2007
  6. Re: Water in the rear pasenger footwell?
    Jun 2007
    I had the same problem on mine too ... turned out to be the drain holes were blocked
    Simon
  7. Re: Water in the rear pasenger footwell?
    Oct 2007
    Hi
    Had exactly the same issue - water was slowly dripping from underneath the car, I was convinced it was a coolant leak. Turned out to be blocked underside drain holes also. Luckily it hadn't got inside - took it to my local garage who cleaned it all out for me free of charge. They recommend mentioning it every time I go in for a service.
    Bruce
  8. Re: Water in the rear pasenger footwell?
    Tyldesley, Manchester, UK
    This has happened once to mine. The nearside rear. Kept a check on it but it has not happened again. In my case I am guessing the rear window was slightly down.
    One German, Two Italian.
  9. Smile Re: Water in the rear pasenger footwell?
    Oct 2007
    Leicester
    Quote Originally Posted by jemthetaxi View Post
    that bloke is a nutter ! have you seen his toast ?
  10. Re: Water in the rear pasenger footwell?
    Thats my day planned out for me then. Took the pollen filter housing apart yesterday and used approx 67 kg of silicone in a vain attempt to stop this leak. Now I see that the drain plugs are indeed blocked so I will have to do those as well. Btw, what a poor design for Battery placement on the 1999 model, wipers windscreen cowl etc all have to come off. What a pain the the ar53!
  1. Water in rear footwell
    By Soo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-08-2009, 08:53 PM
  2. major water leak problem A4 Drivers side rear footwell soaking wet
    By steve888 in forum Audi A4 - Archive Topics
    Last Post: 17-01-2008, 10:27 AM
  3. Water in rear footwell
    By duncan171 in forum 80 - 90
    Last Post: 12-07-2007, 11:59 AM
  4. Water in rear passenger footwell
    By avantiblue in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2007, 01:43 AM
  5. Water in footwell (again!)..
    By toomanycars in forum Audi A4 - Archive Topics
    Last Post: 03-12-2006, 07:00 PM
