Thread: 2009 A4 Avant 2.0TDI
  1. 2009 A4 Avant 2.0TDI
    Feb 2017
    Auckland
    After some advice on the above model car. Any known issues with the engine? I'm in the process of getting service history. The car was originally imported from the UK, presently in NZ. It has 108000kms. Anything additional to the obvious that service history may not reveal. It is 6speed manual. Thanks very much.
  2. Re: 2009 A4 Avant 2.0TDI
    Ardfern
    8 Post(s)
    With such a low mileage, you should have a good one.
    Check cam belt change which should have been done by now, and whatever has been done till now, change the oil and filter every 10,000
    miles using "Longlife" oil and she should run and run.
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  3. Re: 2009 A4 Avant 2.0TDI
    Dec 2008
    Only problems I've had with an A4 143 TDi in the last 100,000 miles apart from normal service parts have been rear springs, egr valve, throttle body valve, glow plugs, door control module, front brake caliper and ignition key holder in dashboard.
    Cars OK but no way near as well built, reliable or economical as my old B6 tdi which was still going strong at 250,000 miles when I sold it.
  4. Re: 2009 A4 Avant 2.0TDI
    Dec 2008
    Also had to replace the door lock in the drivers door at about 80,000 miles
  5. Re: 2009 A4 Avant 2.0TDI
    Dec 2008
    Oh, and the clutch was replaced under warranty at about 30,000 miles. Come to think of it, it's not been very reliable after all!
  1. Looking to buy used A4, 2009 estate, 2.0tdi, what to look out for?
    By WorldUK in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-04-2016, 11:08 PM
  2. 2009 2.0tdi engine management light
    By RobGriff in forum Scirocco - 2008-
    Last Post: 27-02-2015, 02:23 PM
  3. Has 2009 2.0TDI a CR engine?
    By Mike McKinstry in forum Golf MK5 - 2004 - 2009
    Last Post: 16-02-2015, 02:02 PM
  4. 2009 A6 3.0TDI Quatrro
    By st4 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-07-2014, 04:12 PM
  5. C6 2.0tdi s line 170 2009 Headlights
    By nigedvd in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-06-2012, 12:43 AM
