Thread: Oil Temperature Very Low
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Oil Temperature Very Low
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Going back to the OP, what is your coolant temp indicating when the oil temp drops ? Do they tend to decrease together? Some of these engines have a 4/2 way thermostatic valve, not sure on you engine code but i've also read of some cr engines having a second thermostat fitted jnside a hose. Looking at the vw workshop manual there does seem to be a fair bit of gear to get out the way to get to the valve housing, hence you car being in bits and labour costs, and the complete valve assembly should be replaced rather than just the stat.
    If you can get an OBDII reader or vcds you should be able to check and trend oil and coolant sender outputs.
  2. Re: Oil Temperature Very Low
    Feb 2017
    Reading, UK
    Thank you all your replies!!
    Here's a quick update with some more details!:
    I took it back to the garage and they've identified the problem (but they don't know how to fix it!).
    They told me that the EGR Temp Sensor was permanently reading 80C regardless of temp, this was causing the "Accessory Water Pump" to be constantly pumping the water round. They replaced the sensor but this did not fix the issue.
    They have now unplugged the pump, which has made the Oil Temp issue go away, but I'm left without my secondary water pump and my Engine Light on!
    Any ideas?
  1. Please Help Low engine running temperature
    By Chriswsmith in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-04-2014, 07:51 PM
  2. Low oil warning, EGR valve leaking oil, burning oil smell - please help!
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-01-2012, 01:51 PM
  3. Low Oil Temperature
    By DDe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-01-2009, 04:31 PM
  4. Please Help Ambient Temperature too low
    By damnut in forum Touran - Sharan - Caravelle
    Last Post: 22-10-2008, 09:13 AM
  5. Engine Temperature Low
    By davies87 in forum Golf MK3 - 1993 - 1999
    Last Post: 19-10-2008, 06:31 PM
