Quite new here but tearing my hair out! I have a problem with acceleration after Bosch Specialist set up my injectors after a new cam / follower install. Basically its been remapped over 4 years ago and has been great, i had the cam and followers replaced due to a knocking noise and the fact its done 180K. i didn't cure the tapping and it now appears its the bottom end, anyway..
The garage reset the injector ball pins to 180 degree's and when i collected the car it was sluggish and the mpg wasn't good either.
took it back and had the injectors setup again and yes its better but still not perfect, i'm assuming because of the age etc 180 degrees may not be suitable. I have plugged it into the free version of Vagcom and need to know what the fuel levels should be at. Can anyone help?
To summarise its had a remap to 185bhp, hybrid turbo due to old one dying on me new egr cooler pipe to throttle housing as this was split, new fuel temp sensor and egr valve as this was stuck closed.
The car pulled like a train before it went into the garage.
Thanks,
Marc
