Thread: Wet Passenger Footwell - Front.
Results 1 to 10 of 15
  1. Angry Wet Passenger Footwell - Front.
    Jan 2017
    london
    Hi All,
    I've got a 2011 B7 that I've owned for about 18 months with water in the front left (passenger) footwell. Frustratingly, all the guidance I can find about water leaks into this footwell is for b5.5 or before!
    I've had a local garage clear out the two plenum drains at the bottom of the windscreen but it still continues. With the carpet pulled up, I can reach my hand behind the glove box and it seems to be coming from the left ish side of the glove box.
    Windscreen seals seem okay, seems to be an original VW screen so shouldn't be that.
    Door is draining freely out of the bottom
    No sunroof so isn't the drains.
    Happens regardless of aircon, so isn't the drain from that.
    Something I have noticed is if I open the passenger door, there is some foam in the hinge area which is really quite wet, the drivers side is wet at the bottom, but the passenger side is soaked a good way up. I've also got a cracked wheel arch liner on the passenger front wheel but every garage I've spoken to seems to think this cannot be the cause of the wet footwell.
    I've pretty much tried everything I can think of at this point, Main Dealer wants £290 to take a look and source the leak and wants to keep the car for a good few days, which will not work with commuting etc!
    Does anybody have any idea what else I could try? Going Mad!
  2. Re: Wet Passenger Footwell - Front.
    Halifax , Yorkshire
    Cracked wheel arch sounds to be a possibility.
    2.0 TDI Executive Saloon 64 Plate 12.5K miles
  3. Re: Wet Passenger Footwell - Front.
    glasgow
    35 Post(s)
    lift the cover for the plenum area and put a hose in there, gently run water to fill this area up with water
    then go under car and look for the water drains.
    I don't know in your car where they are, but you should have two, going by the VAG group in general
    I take the rubber drains out, as they go hard over time and are less pliable ............................. and to me they are too narrow, easily blocking up
    with a hose gently flowing, water should not be able to puddle much up.
    try and wash the area out gently, lifting cables to get the dirt trapped underneath out of that area
    it is at your own risk to take out the rubber drains, incase it causes rust etc ................................. but I have no qualms in doing it with my own cars
    the cracked wheel arch, could be a red herring, but maybe the car has been damaged before and they just stuck the original wheel arch back on ?
  4. Re: Wet Passenger Footwell - Front.
    Oct 2009
    Stirlingshire
    I know you have problems in the passenger side so this might not help but I had pools of water in the drivers side that was eventually traced to the rubber grommet for the bonnet release cable that goes through the bulkhead.It had popped out so allowing water in the scuttle to leak into the footwell.Hope this helps.
  5. Re: Wet Passenger Footwell - Front.
    Jan 2016
    Winchester Hants
    29 Post(s)
    Quote Originally Posted by xb25436 View Post
    Maybe the shells are manufactured ambidextrous so there could well be a plugged hole that is leaking.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  6. Re: Wet Passenger Footwell - Front.
    Jan 2017
    london
    Thanks all,
    I've just been and had a careful look/comparison between the "water deflector strip" (Volkswagen Passat/Variant (2011 - 2015) - inscriptions/lettering. water deflector. > VAG ETKA Online > Nemiga.com) that runs down the side of the windscreen.
    On the side which doesn't leak, the strip is quite close to the windscreen and the seal aspect goes under the glass all the way up.
    On the side which leaks, the strip is a bit further away from the glass and the seal sits on top of the glass all the way up - apart from a couple of sections where it is under the glass.
    I'm wondering if this is the source of the leak, however I'm not sure which of the two seals above is correct! Any ideas? I'd assume it's supposed to be as it is on my dry side. I can tuck the seal back under fairly easily, so hopefully it will just be that!
    Failing that I'll have a dig around for the bonnet grommet.
  7. Re: Wet Passenger Footwell - Front.
    Dec 2014
    Bedford
    42 Post(s)
    Seen this problem before on the Passat whilst working at Volkswagen. I'm confident your problem is gone now.
    Sent from my SM-G900F using Tapatalk
    0 2 0
  8. Re: Wet Passenger Footwell - Front.
    Apr 2015
    Damascus, Syria
    Hi All,
    so the culprit for the leaking was a split seam, lower windscreen / front wing area ? Would this have been a manufacturing fault, or caused by crash damage, as the wing liner was split too.
    Just curious as there are lots of posts about leaks... mainly blocked plenum drains, or air filter gasket not working.
    All the Best, Jim.
  9. Re: Wet Passenger Footwell - Front.
    Dec 2021
    uk
    Hi All,
    Currently dealing with 2015 VW CC issue very similar. VW have had the interior out, carpets up, arch liner out. Cant find the issue. now want 500 to take dash out
  10. Re: Wet Passenger Footwell - Front.
    Dec 2014
    Bedford
    42 Post(s)
    The seam issue usually allows water in when driving, not usually when the vehicle is static. So a PITA to find.
    Sent from my SM-G970F using Tapatalk
  1. Question Wet passenger footwell
    By simonrk57 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-11-2012, 06:45 PM
  2. Passenger footwell soaking wet!
    By henners38 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 20-01-2010, 08:37 PM
  3. Wet carpet in passenger footwell??
    By Midnightsky in forum Bora - 1998 - 2005
    Last Post: 25-12-2009, 09:41 PM
  4. Wet Passenger Footwell
    By Evoblade in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-02-2009, 11:35 AM
