Thread: rattling noise, overheating, Rough Idle and Misfire on A4 B6 2.0
  1. rattling noise, overheating, Rough Idle and Misfire on A4 B6 2.0
    Feb 2017
    Nigeria
    Good morning all, I am less than an hour old on this forum, I have a worrying rough idle issue on my A4 B6 2.0 on a scan with a launch obd2 tool it showed cylinder 3 and 4 misfire...which am currently trying to deal with, by purchasing a new set of sparkplugs...to no effect!
    Now I noticed that the previous owner applied cello-tape on the air duct leading to the mass airflow metre and now the tape is getting peeled... could this be responsible?
    Second issue: I had the dreaded oil pump pick up tube issue, the oil warning lights kept flashing in the middle of nowhere and the car message was "stop driving" eventually I got a VAG mech who opened the oil sump and cleaned the pickup tube created some larger holes ... and gbam! handed my car back after a whole day's work.... Now I noticed that at start up my engine topside gives a chain rattling noise which quietens after 6secs or with a slight rev .... My question...how do I get this noise to go away permanently?
    Third issue... I discovered also that the temperature gauge on the dash works when it wants to and that the coolant reservoir leaks mysteriously hence an occasional overheating issue.... any solution?
    Thank you.... am trying to love this car....any help would be appreciated... previous cars were the w202 C180, W210 E200.... my first car to be a non-benz
  2. Re: rattling noise, overheating, Rough Idle and Misfire on A4 B6 2.0
    Feb 2017
    Nigeria
    well I think I have to revert to the Toyota if the acclaimed audi thread can not even assist.... then owning the car ain't worth it
  3. Re: rattling noise, overheating, Rough Idle and Misfire on A4 B6 2.0
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Before you storm off in the Toyota, to answer some of your queries; try moving coil packs from non misfiring cylinders to misfiring cylinders, see if the misfire moves with the coil pack. If so replace. If misfire remains do compression test. Replace cellotaped air ducting with non damaged duct.To cure rattling time chain, replace chain and tensioner. For intermittent coolant loss and overheating, do sniff test in coolant header bottle, check for cottage cheese in oil filler, suspect head gasket, remove head and pressure test, replace components as necessary. For non functioning temperature gauge, replace temperature sender unit.
    0 2 0
  1. Replies: 0
    Last Post: 29-10-2015, 12:52 PM
  2. 1.8t awu Misfire & rough idle
    By marbar2k in forum Beetle 2000-
    Last Post: 14-02-2011, 12:47 AM
  3. Rough noise at idle
    By passat130se in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-08-2010, 04:53 PM
  4. Audi A6 2.8 V6 Rough Idle / Misfire
    By jayfret in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-01-2009, 11:43 PM
  5. Overheating and Rough Idle Bora PD100
    By amygoodness in forum Bora - 1998 - 2005
    Last Post: 23-01-2008, 11:05 PM
