Thread: Turn engine off when leaving car
  1. Turn engine off when leaving car
    Sep 2016
    Halifax
    When I first got my C7 in September, it had a feature that would shut the engine off and turn the ignition off when I opened the driver's door to leave the car.
    Now it no longer does that and I can't see a setting for it.
    Am i imagining this and have I gone mad? Or is there a setting somewhere.
    Sent from my ONEPLUS A3003 using Tapatalk
  2. Re: Turn engine off when leaving car
    Yateley, Hampshire
    Think you have to push the stop button first? I leave mine running if frosty so obviously i get out lock it and leave it running to warm up. Not heard of this before? Could be a setting in the car menu?
  3. Re: Turn engine off when leaving car
    Feb 2016
    Hungary
    116 Post(s)
    I think your issue was explained in the A6/C7 tips and tricks section in the oppsite way:
    "10. Disabling engine stop when opening driver's door.
    Recode the Central Convenience module to STOP the engine from turning off when you get out, having moved the car.
    [Select]
    [46 - Central Conv.]
    [Coding - 07]
    [Long Coding Helper]
    Click on the red byte (below) and in the binary code you will see: 00000111
    Change it to: 00001111
    ie. with 1111 at the end not 111
    Tab into the next bit box and you will see the code change to 0F (013F062220B90000832009042001040700000000000000000000000 00000 to 013B062220B90000832009042001040F00000000000000000000000 00000)
    [close the long code helper]
    [Do It!]"
    So maybe you have to reverse this setting with a VCDS.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  1. Android and MMI high - no phone signal AFTER leaving car?
    By mikenott in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-12-2013, 01:06 AM
  2. Please Help I cant turn off my car!
    By Pod1200s in forum 80 - 90
    Last Post: 21-02-2011, 10:51 PM
  3. Leaving Engine running with door closed
    By yus786 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-10-2010, 11:01 PM
  4. Please Help Engine management light is on, Fan turn on when engine is off, made the battery flat, help
    By shinghu in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2009, 02:15 AM
  5. leaving car long term
    By osprey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-02-2008, 01:01 AM
