Thread: A3 Cab water ingress to boot - experience & fixes sought
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: A3 Cab water ingress to boot - experience & fixes sought
    Aug 2014
    Caerphilly
    Hi drmw
    Did you get your leak sorted out by the non franchised dealer as mine still has a small leak on the same side as yours so if they found the cause could you post it please. As I will have to start from scratch with mine . So hope you might be able to provide some information.
    Westo
  2. Re: A3 Cab water ingress to boot - experience & fixes sought
    Jan 2017
    Woking UK
    Found this old post & wanted to see if the solutions worked? I have exactly the same problem on my 2009 A3 cab, which I have had for about 6 years. Water intermittently appears in the spare wheel well & appears to be coming from the passenger side wheel arch. The water only appears after driving in rain not when stationary in rain. So suspect the drain pipe is partially blocked and the water backs up & overflows into the boot aggravated by the movement of the car. Now it is dry weather again, I will check these drain pipes for blockages & associated seals & report back.
  1. water ingress
    By duggie79 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-01-2016, 10:42 AM
  2. Water ingress
    By jillbrit in forum Golf MK5 - 2004 - 2009
    Last Post: 06-02-2014, 07:35 PM
  3. Water Ingress in boot of A4 Cab
    By bertieauld in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-02-2008, 12:40 PM
  4. Water ingress into VW Passat Boot
    By peter.james in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-08-2007, 07:21 AM
  5. Water ingress in Boot on Golf Mk 4
    By tobert in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-05-2007, 12:11 PM
