Thread: A6 2011 - Flat Battery & Replacing
Results 1 to 10 of 10
  1. A6 2011 - Flat Battery & Replacing
    Jan 2015
    Surrey
    Hi All,
    I’ve had a search for the answers and as yet unable to find them so i hope it’s okay to ask them here.
    The car in question is a A6 2.0TDI diesel 2011, after the car has been stationary for a couple of weeks and what with the cold weather the battery is low and now only give around 5v. Putting the battery on a CTEK optimiser for a few days it run though the first two modes that given an error at the third stage reporting the battery won’t take a charge.
    I’ve settled on a replacement battery is required and checked and sourced the matching model (H15 Varta Start-Stop Plus AGM Car Battery 12V 105Ah), i understand that the battery needed to be coded to the car using the details from the new battery, if i swap the batteries over will the car run before it’s coded? is the coding to help with the battery conditioning / management?
    With the existing battery being so low (no electrics on the car at all) is there a chance of other problems such as key coding?
    Just trying to prepare myself for what may happen and needs doing after the battery is replaced.
    Thanks in advance.
  2. Re: A6 2011 - Flat Battery & Replacing
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Just replace the battery and then code it later. Car will work fine and no need to recode keys etc. Coding the battery to the car is to tell the car that 'hey im fine just give me all the normal juice that i need no supplements plese'
    0 2 0
  3. Re: A6 2011 - Flat Battery & Replacing
    Jan 2015
    Surrey
    Thanks, will do.
  4. Re: A6 2011 - Flat Battery & Replacing
    Mar 2014
    Edinburgh
    235 Post(s)
    I'm interested in what the actual coding does?
    Surely it's just a 12v battery like any other one. Just needs to hold enough charge to keep car running
  5. Re: A6 2011 - Flat Battery & Replacing
    Dec 2016
    Ireland
    The BEM code on the battery allows the car to track what battery is installed. Then it learns parameters of the battery such as age, how well it charges, how much power it supplies etc and compensates for those things. When you put in a new battery without adding the new BEM code the car still compensates as though an old battery is there. But even without entering the BEM it will learn the characteristics of the new battery over time anyway. Some things like start/stop might not work as well/at all until the new battery characteristics are learned though.
    See: http://www.bannerbatterien.com.cn/ba...echnik_GB3.pdf
  6. Re: A6 2011 - Flat Battery & Replacing
    Jan 2015
    Surrey
    I'm pleased to say it was a straightforward swap and no real issues, one thing i have noticed is the start/stop hasn’t kicked in yet. I’m assuming this is because the car isn’t aware of the batteries condition yet?
    I've only done a 40 minute return journey on top of local trips, will keep an eye on it, my plan is to ask if anyone local with VCDS can code it for beer tokens.
  7. Re: A6 2011 - Flat Battery & Replacing
    Feb 2016
    Hungary
    116 Post(s)
    Quote Originally Posted by DJS11 View Post
    IMHO the ambient temperature is too cold to allow the use of the start/stop system.
    The engine and the other systems could cold down too fast, so it doesn't worth to shut down the engine for some seconds, as a colder start could cause a harm in the engine, and it does not worth to take the risk to spare a minimum amount on the fuel consumption.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  8. Re: A6 2011 - Flat Battery & Replacing
    Apr 2009
    Surrey
    182 Post(s)
    Quote Originally Posted by AT. View Post
    OP is in Surrey where it is 8c this morning so ambient temperature is not an issue. Appreciate that in Hungary the temperature is somewhat colder
  9. Re: A6 2011 - Flat Battery & Replacing
    Feb 2016
    Hungary
    116 Post(s)
    This argument doesn't sounds like a contradiction for me, because if you can believe, that the -2,5°C can affect whether the start/stop system will work or not, then there is no argument to declare, that the 8°C is such warm weather, when the start/stop system must work.
    Honestly, I don't remember when was the last time, when the start/stop system stopped my engine for the last time.
    Anyway it was just an idea.
  10. Re: A6 2011 - Flat Battery & Replacing
    Feb 2016
    Hungary
    116 Post(s)
    Quote Originally Posted by johnsimcox View Post
    I just remembered this issue, and something strange happened to me yesterday and today. As I mentioned earlier, I don't remember when my start/stop worked for the last time. However yesterday I was surprised, as the start/stop worked for me, so I checked the temperature, and it was 8.0°C by the DIS.
    However, today I stopped in a traffic jam, and the start/stop doesn't worked, so I checked the ambient temperature, and it was 7.5°C b to the DIS...
    Strange
    Strange indeed, maybe there were other reasons (ie. the engine was not fully heated today)
  1. Flat Battery
    By steely_resolve in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 22-06-2011, 08:39 PM
  2. Question New (2011) Polo 1.4 (85bhp) engine characteristics/flat spot
    By roosevelt1st in forum Polo - Derby - Lupo - Fox
    Last Post: 08-06-2011, 08:47 PM
  3. flat battery and 2 amp drain.
    By Ben in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-05-2011, 02:14 PM
  4. Battery keeps going flat
    By csharma84 in forum Golf MK5 - 2004 - 2009
    Last Post: 20-08-2009, 05:38 PM
  5. Please Help More questions . . . . & flat battery !
    By stangrenade in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-11-2008, 04:04 PM
