Thread: Charge pressure control
  1. Charge pressure control
    Mar 2016
    GB
    1.9 130bhp ive got this code up after givin it a hard blast and it went into limp mode switch off and on again and its cured dosent do it the whole time but she dosent have the same poke as before and now it gives a louder pew than normal when you change gears has anyone encountered this before , il give the turbo shaft a feel tomoro hopefully shes not bad
    Sent from my SM-T710 using Tapatalk
  2. Re: Charge pressure control
    Jan 2009
    Birmingham
    36 Post(s)
    Overboosting turbo most likely carbon vnt build up jamming up the actuater arm or could be you n75 valve
  3. Re: Charge pressure control
    Mar 2016
    GB
    Gave it a clean today with mr muscle and it appears to have sorted the problem and very little play on the turbo quite suprised wen the engine has 282k
  4. Re: Charge pressure control
    134 Post(s)
    2005 Post(s)
    Mr Muscle is water based, this causes corrosion of the shaft and piston ring and ultimately the turbo fills the exhaust with oil.
  5. Re: Charge pressure control
    Mar 2016
    GB
    Oh dear, least its cured the problem for now just a £300 car no heartache if she goes lol
  6. Re: Charge pressure control
    134 Post(s)
    2005 Post(s)
    Quote Originally Posted by heelinder View Post
    just a £300 car
    NOPE, it is a £28K car, a 15 year old £28K car but still, a £28K car and cars don't cost less to fix as they get older, they cost more to fix but less to buy.
    0 2 0
  1. 17964/P1556 - Charge Pressure Control: Negative Deviation
    By Jamiem in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-09-2017, 03:21 PM
  2. Loss of power 17965-charge pressure control
    By waynetdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2012, 12:33 PM
  3. Charge Pressure Control: Negative Deviation
    By iainst26 in forum Octavia
    Last Post: 06-07-2010, 06:52 PM
  4. Question 17965 - Charge Pressure Control: Positive Deviation
    By mobitune in forum Golf MK4 - 1999 - 2004
    Last Post: 09-09-2009, 06:17 PM
  5. 17958 - Charge Pressure: Control Deviation
    By andy1max in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2008, 08:39 PM
