I have a 2008 a3 tdi 138. To cut a long story short I have replaced the engine as last owner damaged the old unit. All sensors and ancillaries are from the old unit. Any help would be appreciated
audi
JP
jamie postuma
Tue 24/01/2017 18:53
Inbox; Sent Items
To:
jamie postuma (jamiepostuma1@hotmail.com);
Evernote
Tuesday,24,January,2017,18:05:58:27963
VCDS Version: 17.1.2.0 (x64) HEX-V2 CB: 0.4334.4
Data version: 20170107 DS267.0
Ross-Tech: Home
VIN: WAUZZZ8P89A033321 License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56
VIN: WAUZZZ8P89A033321 Mileage: 103700km-64436miles
01-Engine -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BQ HW: 03L 906 022 BQ
Component: R4 2,0L EDC G000SG 3066
Revision: 13H01--- Serial number: AUX7Z0H7FNF0A4
Coding: 0000072
Shop #: WSC 14557 551 00000
VCID: 75B4EBA6B9C7E51F0E5-8020
2 Faults Found:
008214 - Intake Manifold Flap Position Sensor (Bank 1)
P2016 - 000 - Short to Ground
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 103700 km
Time Indication: 0
Date: 2000.00.00
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: 6.3 %
Lambda: 3.2 %
Voltage: 0.228 V
Bin. Bits: 00000000
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 103700 km
Time Indication: 0
Date: 2016.07.19
Time: 00:00:04
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: 6.3 %
Lambda: 3.2 %
Voltage: 0.228 V
Bin. Bits: 00000000
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 13424012092500FDC80E02E6901A00823800
Shop #: WSC 06314 000 00000
VCID: 74B2D6A2BEBDFC1739B-8020
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000378 Serial number: 8P0820043BG
Shop #: WSC 00000 000 00000
VCID: 72BED0BAC8A9F2272B7-8026
3 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 4
Reset counter: 182
Mileage: 103700 km
Time Indication: 0
Date: 2016.04.09
Time: 21:09:54
Freeze Frame:
Voltage: 9.10 V
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 182
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 142
Mileage: 103700 km
Time Indication: 0
Date: 2016.08.01
Time: 03:05:12
Freeze Frame:
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008732809
Coding: 118A0F07A0141380EF00000A4F00000000084E056406000300 2000000000
Shop #: WSC 06314 000 08192
VCID: 48CA52529EB528F7A53-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
2 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 142
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 10.20 V
OFF
ON
OFF
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 142
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 10.25 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142413039303030384A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 49CC5756893FD1FFBAD-801C
Crash sensor for side airbag: driver side:
Serial number: 34928RB400003F4D1AE%
Crash sensor for side airbag: front passenger side:
Serial number: 35028RB400003FD4992T
Crash sensor for side airbag: rear: driver side:
Serial number: 35128RB400003F4CC1CY
Crash sensor for side airbag: rear: passenger side:
Serial number: 35228RB400003FD3043H
Crash sensor for front airbag: driver side:
Serial number: 35547RB40000407C638K
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB40000407C650F
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002042
VCID: 41DC4F76BD8F19BF62D-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2247H006005091
Coding: 0004428
Shop #: WSC 01215 210 175981
VCID: 392C2796D55F417F2AD-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0880908BC
Coding: E9811F061002020101
VCID: 35342BA6F947A51FCE5-8060
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H18006 Serial number: AUX7Z0H7FNF0A4
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000564
VCID: 43D0457EA7930BAF701-8016
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A0E08DA20F9FAE7537-807E
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 103700 km
Time Indication: 0
Date: 2016.07.19
Time: 01:10:18
Freeze Frame:
Battery Volts: 12.0 V
DD
Temperature: 13.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D2D8505489AC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
Component: AB2 SUBWOOFERBOXH30 0160
Revision: 00006 Serial number: 30659850248431
VCID: 343216A2F23DBC17F9B-8060
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000564
VCID: 44D24662A29D0C9749B-8010
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Revision: 00000001 Serial number:
Coding: 0000013
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H03 0270
Revision: 00H03000 Serial number: AUZ1Z3H8947049
Coding: 0330211
VCID: 3FD8498ECB7B6F4F149-806A
1 Fault Found:
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 142
Mileage: 103700 km
Time Indication: 0
Date: 2016.08.01
Time: 03:06:42
