Thread: 1.9 TDI starting issues
Results 1 to 10 of 15
  1. 1.9 TDI starting issues
    Nov 2008
    Hello,
    newbie here so please be gentle. I have a mk4 1.9 TDI 2001 that has developed a problem starting. I will start from the beginning as it may have some relevance.
    car stared fine this morning with no issues, on my drive to work there was something in the road which went under the car and made a loud clang but no issues with the car that I could see when I got to work. After work, again started fine and when I went to pull onto my drive it cut out. When I restarted it the accelerator was non responsive and the revs were stuck at 1800 rpm. After a couple of mins of starting and stopping the engine it cleared and I pulled onto the driveway. I then went out a few hours later and again started fine, as I pulled off the drive and down the road it cut out so I pulled in. Now all that happens is that when I turn it over it starts but then cuts out, the accelerator is non responsive but have also noticed a lot of exhaust fumes come back up into the engine bay (maybe nothing other than wind direction, but looked strange).
    appologies for the long winded message but am hoping someone maybe able to point me in the right direction.
    cheers
  2. Re: 1.9 TDI starting issues
    7 Post(s)
    You need to have a look underneath to find out what got broken. Until that is done any and everything is a guess.
  3. Re: 1.9 TDI starting issues
    Nov 2008
    I have taken a good look underneath and there is no damage, I sensors or electrics that could have been damaged. Only thing I have noticed is that there is exhaust fumes come from what appears to be the flexible pipe from the manifold, not sure if this is a new problem or just noticed now the car is stationary.
  4. Re: 1.9 TDI starting issues
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    check the fuel lines, running along under the drivers side IIRC.
  5. Re: 1.9 TDI starting issues
    Nov 2008
    Hi Rob69,
    Checked them, there is fuel coming through the filter and into the clear fuel like into injectors (well I think that's where it goes). Have also connected a code reader and there is no faults showing up
  6. Re: 1.9 TDI starting issues
    Nov 2010
    104 Post(s)
    How do you know that fuel is coming through the clear line? can you see air bubbles moving along the line ? if the diesel is air free it is not normally possible to see it flowing. if it has bubbles that might be your problem.
  7. Re: 1.9 TDI starting issues
    Nov 2008
    There has always been bubbles, and I have had the fault before when I have had an airlock and have cleared that, I did think it could still be that issue, but have always got over it by spraying a bit of deodorant into the air intake and then keeping it revving when starting, but now when I press the accelerator it does nothing. Is there a best way to remove the air bubbles that I can do myself or does it require specialist tools
  8. Re: 1.9 TDI starting issues
    Nov 2010
    104 Post(s)
    I reckon you should be taking it into a garage to get sorted, there should be no air bubbles in the fuel supply line, you have a leak in the fuel system drawing air in, sounds like this running fault has nothing to do with the item you ran over in the road and has beena long standing issue. I wouldn't spray deodorant anywhere near an engine, I think they use butane as the propellant, lucky you still have your eyebrows !!
  9. Re: 1.9 TDI starting issues
    Apr 2016
    Ashburton
    This fault sounds more light a sticking or faulty throttle body due to Carbon build up this will cause stalling.
  10. Re: 1.9 TDI starting issues
    Nov 2008
    Well I have managed to get it to a garage and the fault is "Fuel adjuster precision sensor fault" The garage said the diesel pumps are coded to the car so a straight swap s not an option and a rebuild on the one in the car is about £1000.
  1. 2.5 tdi quattro starting issues
    By Alex Welham in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-07-2011, 08:18 PM
  2. audi quattro 2.5 tdi a6 avant starting issues
    By rooos in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-05-2009, 09:54 PM
  3. Question 2003 A4 V6 TDi starting issues and is my car can bus ?
    By ShaunD in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2009, 04:27 PM
  4. Please Help 1.9 TDi (AFN) starting issues
    By Aeikostx in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-09-2008, 01:02 AM
  5. Hot starting issues on TDi 130
    By Passat130 in forum Passat - Archive Topics
    Last Post: 12-07-2006, 06:40 PM
