Thread: BITDI DPF, EM Light and Glow plug flashing. Limp home
Results 1 to 10 of 18
  1. BITDI DPF, EM Light and Glow plug flashing. Limp home
    Jun 2015
    Europe
    So my 2 1/2 years old BITDi developed some issues in this order.
    1. DPF service required - managed to clear this via the 40-45 mph 2500 rpm 30 min drive solution.
    2. DPF service light & Engine Management light.
    3. DPF service light & Engine Management light & glow plug indicator flashing ( further engine management issues at deeper level). Car limp home mode
    Car into Audi. Story in this order.
    1. Audi roadside assist turned and couldn't rectify the issues. Followed me into Audi.
    2. Audi diagnosed a software update should fix issue. Could not come under warranty as car had been " chipped" as verified by the German Audi computer system.
    3. Car left Audi and 6 hrs latter and Engine Management light back on no limp[ home mode.
    4. Audi roadside assist twice came out and reset but each time light came on.
    5. Back to dealer diagnosed MAF centre giving fault readings. Replace MAF sensor.
    6. Running car as we speak.
    So first I've seen any DPF issues with a BITDI. Useful info for any other interested parties. Still love my car though and Audi where pretty reasonable with their charges. Chip tuner was confused why a tune had been detected. Audi say even if the tune has been removed as in my case they can see that thats taken place and the car and Germany communicate directly with no dealer involvement.
    Also co incidentally i started using premium diesel just weeks before this all started.
  2. Re: BITDI DPF, EM Light and Glow plug flashing. Limp home
    Jul 2016
    Midlands
    Which premium diesel did you start to use? I seem to get a lot of regens when on Shell v power and slightly less on BP Ultimate. Esso supreme seems the best so far.
    Mercedes CLA 45 AMG Shooting Brake
  3. Re: BITDI DPF, EM Light and Glow plug flashing. Limp home
    Sep 2016
    Chesterfield, UK
    I've never had any issues with my engine. And I drive 24 miles to work and back everyday in various speed zones. Just make sure you open it up once in a while!
  4. Re: BITDI DPF, EM Light and Glow plug flashing. Limp home
    May 2014
    Darlington
    78 Post(s)
    Wonder why the tuner was confused about Audi detecting the remap! Have a search for TD1 and you will find a lot of information about this. Any time the ECU is written to it's logged by the ECU, also the checksum no longer matches the original map checksum value.
  5. Re: BITDI DPF, EM Light and Glow plug flashing. Limp home
    Aberdeen
    63 Post(s)
    My boss has the SQ5 and got the engine management light. I thought it might be the dpf so told him to run it home in sport. This cleared the problem. He has low mileage and only does long runs but I think the issue is the tiptronic using 8th gear so the revs are very low. Never had any issue with my bitdi but I drove a bit harder than him and did a long motorway journey every couple of months. 51k in 2 years when i sold mine.
  6. Re: BITDI DPF, EM Light and Glow plug flashing. Limp home
    Mar 2017
    Aberdeen
    Hi Scott K
    Apologies for the unsolicited message. I may have picked it up wrong on the forum but there was a message that suggested you live in Aberdeen and that you had a VCDS.
    I've got the most annoying problem with my B8 Audi A4 where the brake pad warning light comes on intermittently and despite short circuiting the wire before the pads the problem persists. I suspect there may be corrosion at the main wiring loom and so don't really want to touch it.
    However I believe that the VCDS can be used to disable the brake pad warning message in the instruments section.
    If the above is true and you do live in Aberdeen and have a VCDS I wonder if you'd be able to help me. I live in Midstocket and would be happy to pay you for your time.
    Many thanks for reading this far!
    David
  7. Re: BITDI DPF, EM Light and Glow plug flashing. Limp home
    Aberdeen
    63 Post(s)
    Hi David
    I am in Aberdeen. No problem helping if you know what the coding is
    Cheers, Scott
  8. Re: BITDI DPF, EM Light and Glow plug flashing. Limp home
    Mar 2017
    Aberdeen
    Thanks Scott,
    I'm a VCDS novice, however I have established from other posts that the coding follows the pattern below.
    If that looks about right to you (obviously changing the canadian part to UK, please drop me an email (struddy@btinternet.com) and let me know a convenient time for you that you'd be able to help me.
    Thanks again
    David
    [Select]
    [17 - Instruments]
    [Recode - 07]
    Write down the existing coding for future reference.
    Enter 5-digit code from below
    [Do It!]
    Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
    00 - No available equipment
    +01 - Brakepad wear sensor warning active
    +02 - Seatbelt warning active
    +04 - Washer fluid level warning active
    Look at the third digit in the coding (Market version):
    1 - "EU" 24 hour clock (may result in odometer in km in 2002+ clusters)
    2 - "USA" 12 hour clock
    3 - "Canada" 12 hour clock (may result in odometer in km in 2002+ clusters)
    "The third digit in the code is the country code. The codes are:
    4 - "UK" 24 hour clock (should result in odometer in miles)
    5 - Japan
    6 - Saudi Arabia
    7 - Australia
    Look at the fourth digit in the coding (Cylinders):
    3 - No Service Interval (2002+ models)
    4 - 4-cylinder (1999-2001 models)
    6 - 6-cylinder (1999-2001 models)
    Look at the fifth digit in the coding (Distance impulse multiplier):
    2 - 3538
    4 - 3648 (some 2002+ models)
    So, if you want to have Seatbelt warning and washer fluid warning only in a 2001 Canadian 6-cylinder vehicle, (add 00+02+04 = 06),3,6,2 = 06362.
  9. Re: BITDI DPF, EM Light and Glow plug flashing. Limp home
    Jun 2015
    Europe
    Mines is at just over 30 k in 3 years and it gets plenty of boot. Audi updated the software and now no issues.
    Quote Originally Posted by Scott K View Post
  10. Re: BITDI DPF, EM Light and Glow plug flashing. Limp home
    Jun 2015
    Europe
    I spoke to the tuner and they still are clear that it should never be seen. Somewhere between Audi and them is the answer - i was pretty ****** off.
    Moving on. Since the warranty is voided I'm going for stage 3 460 cup 900 nm torque tune due to complete later this month. This involves an RS6 air box and K N filter which i have already fitted. A Wagner competition intercooler due to land this week and a trip to Holland to JDR engineering for the engine tune.
    Quote Originally Posted by B5NUT View Post
  1. Please Help dpf flashing glow plug and eng management light on??
    By ahsanx in forum Golf MK5 - 2004 - 2009
    Last Post: 17-01-2019, 09:52 PM
  2. Please Help passat b6 DPF FAULT LIGHT AND glow plug FLASHING.
    By usa in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-04-2015, 02:39 AM
  3. Please Help Flashing glow plug warning light/limp mode
    By simonrk57 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-08-2012, 05:00 PM
  4. DPF, Flashing Glow Plug and Engine Mang Light on..
    By Imizz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-08-2011, 01:06 PM
  5. Question a4 tdi in limp mode and glow plug light flashing
    By iwa.r8 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2010, 12:33 AM
