Thread: Dash error message - oil sensor + ESP
  1. Dash error message - oil sensor + ESP
    Jun 2011
    chester
    Hi friends, thanks in advance for help.
    I have 2 lights appearing on my dash, ESP light is lit up on its logo, and oil sensor light appears on the centre bit where warnings such as low fuel and wiper washer fluid appear. There is a chain of faults/changes which have arose due to these lights
    There is a burnt smell in the cabin, a bit like cigarette smoke.
    Climate control not working at all.
    I've noticed a faulty reading on dash regarding outside temperature appearing in the minuses, its clearly been +6 degrees outside lately.
    I have checked the fuse box, the 3 fuses which were blown have been replaced. All fault lights/faults went off/fixed, but within 2 minutes of replacing them 2 of them have blown the fuse again.
    So I'm back to square 1 with the 2 fault lights, climate control not working plus dodgy outside temperature.
    I'm really confused, nothing makes sense.
    I've hooked up vag com and the following codes appear, ECU Load error. see attached.
    Please help, sorry for being long winded.
    Sent from my ASUS_Z016D using Tapatalk
  2. Re: Dash error message - oil sensor + ESP
    Jul 2007
    glasgow
    35 Post(s)
    need to check the wiring loom
    fuses don't blow unless they are faulty, wrong size etc
    if its frosty, your battery gets really tested and any dud cell(s) will throw up an ESP fault ................................... related to the outside temp fault , again cheap to buy
    it doesn't cost anything to test your battery or alternator output
    the wiring loom, well that's free to have a look by yourself , any rubbing on wires, green gunge present, push all connections together etc maybe buying a new one or perhaps
    start with the wiring loom, buy the genuine vcds to read the codes, otherwise the muckabout factor and buying needless parts will far outweigh the cost
    I use an autel vag505 and it reads all the codes if your on a budget and resets oil lights/ winds back electronic hand brake if you do your own diy and want a code reader that will future proof yourself for a good while yet
  3. Re: Dash error message - oil sensor + ESP
    Jun 2011
    chester
    Hi, thanks for your help.
    You know what I replaced the fuses once again. I know there's something tripping it which is obviously causing this to happen.
    However, its not tripped again, all seems fine now. Fingers crossed it will stay like this. If not I'll have to follow your advice 👍
  4. Re: Dash error message - oil sensor + ESP
    Jul 2007
    glasgow
    35 Post(s)
    No problem
    Fuses are like anything else, you get dodgy batches and cheap makes will not last. The 2006 models have fuses in the cigarette lighters that fail for no reason, just a bad batch/ cheap fuses supplied
  5. Re: Dash error message - oil sensor + ESP
    Jul 2007
    glasgow
    35 Post(s)
    as an interest thing, the first thing your age of car does is check the battery at start up.
    any fault and the ESP light comes on, as the car thinks theres not enough electricity to work the brakes
    The newer model than yours checks the battery after 8 minutes, giving the battery a chance to charge up & warm up. Your car doesn't allow the battery to get charged up, so any dud cell(s) or alternator not fully charging the battery will cause an ESP fault
    Cold weather kills batterys with dud cell(s), a bit like putting your dead phone in your pocket to heat up & hey presto the battery by magic has some charge
  6. Re: Dash error message - oil sensor + ESP
    Jun 2011
    chester
    Thanks niall, appreciate your advice.
  1. A8 D4 Error Message
    By imkbm67 in forum In Car Entertainment
    Last Post: 18-11-2015, 01:33 PM
  2. ESP, Crash sensor and other error lights.
    By zsharmask in forum VCDS - Help Requests
    Last Post: 13-03-2013, 08:04 PM
  3. Oil Min Light Error - Oil Level Sensor Fault (2006 2.0l TDi S-Line)
    By i_786_i in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2012, 11:24 AM
  4. Please Help error message
    By villager in forum Ibiza - Cordoba
    Last Post: 04-12-2008, 10:46 PM
  5. Oil sensor message
    By jms in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-07-2007, 04:55 PM
