Thread: 2002 Audi allroad 2.5tdi HVAC issues
Results 1 to 9 of 9
  1. 2002 Audi allroad 2.5tdi HVAC issues
    Aug 2008
    Isle of Skye
    Hello, I am currently fault finding some issues with the above car and am kind of stumped at the moment. Firstly, I apologise that this will be a long post but I want to include all the info and steps I have done so far.
    So, initially I will explain the problem. The way the car was before i started investigating was that every aspect of the HVAC system worked as it should - no solid 'ECON' light was displayed and all functions worked, APART from no cold air from the system and no triggering of the AC clutch. There was also one fault code: 01582 - Signal for Coolant Temperature 30-00 - Open or Short to Plus
    Below is the full fault code scan - clean bill of health apart from the HVAC.
    Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
    Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
    75 76 77
    VIN: WAUZZZ4B12N117666
    Address 01: Engine Labels: 059-907-401-AKE.clb
    Part No: 4Z7 907 401 B
    Component: 2.5l/4VTEDC G000SG D06
    Coding: 01015
    Shop #: WSC 02325
    VCID: 3C7CE95B2C6BA0A2D5-4B00
    Subsystem 1 - Part No: 00017059
    Component: 130 106EC150_1.R75775723283
    WAUZZZ4B12N117666 AUZ7Z0B2054918
    No fault code found.
    Address 03: ABS Brakes Labels: 8D0-907-389.lbl
    Part No: 4Z7 907 389 A
    Component: ABS/ESP allrad D55
    Coding: 06455
    Shop #: WSC 00665
    VCID: 4A90BF8376BF0E1257-5120
    Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
    Part No: 4B0 820 043 H
    Component: A6-Klimavollautomat D64
    Coding: 00064
    Shop #: WSC 02335
    VCID: 1F463ED79DBDDBBAD0-2586
    1 Fault Found:
    Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
    Part No: 4Z7 959 655 D
    Component: Airbag 8.4E 5000
    Coding: 0001106
    Shop #: WSC 02325 785 00200
    VCID: 50A4ADEBC0E334C219-513C
    Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
    Part No: 4B0 920 981 JX
    Component: KOMBI+WEGFAHRS. VDO D12
    Coding: 04460
    Shop #: WSC 00665
    VCID: 050A4CBF1F21216AFA-513C
    Address 34: Level Control Labels: 4Z7-907-553.lbl
    Part No: 4Z7 907 553 E
    Component: - 2C1A1 D040
    Coding: 25500
    Shop #: WSC 09999
    VCID: 479686B765ADF37A48-5120
    Address 35: Centr. Locks Labels: 4B0-962-258.lbl
    Part No: 4B0 962 258 K
    Component: Zentralverrieg.,DWA D35
    Coding: 04939
    Shop #: WSC 00873
    VCID: 3162C86FFB295DCA76-4ECA
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00002
    Shop #: WSC 02325
    VCID: 60C47D2BE043A442A9-4B32
    Address 55: Headlight Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D07
    Coding: 00030
    Shop #: WSC 02325
    VCID: 040C51BB141B1862ED-4B18
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 4B0 035 186 G
    Component: concert II GRO 0008
    Coding: 00201
    Shop #: WSC 00000
    VCID: 244C313BB4DBF8628D-4AE6
    So, with that fault code I did some Googling, but didn't find much of help, apart from some info that the control unit in the dash most likely housed this sensor. I then did some VAGCOM'ing and noted that when scanning the system -40°C appeared on the dash temp display and also in Group 11 -40°C appeared. Googling that basically told me that this would prevent the air conditioning from starting up as the system already thinks it is sub zero! Of course this does not help me much either, so I did more digging and found a suggestion that the control unit in my car was designed for pre-2002 models and if fitted to post 2002 cars the fault code and -40°C issue would be the likely result. I searched the part number 4B0 820 043 H and true enough there is a lot of evidence that suggests this is pre-2002. Also the date sticker on the unit itself is from year 2000. Also of note is that this unit did not match the rest of the dashboard - it was black with regular smooth plastic buttons, yet the rest of the dash in this car is of the 'soft' easy worn material and the buttons on the stereo are very worn.
    With the above info I went online and tried to find a post-2002 control unit. I found a 4B0 820 043 AQ which according to ETKA online should be suitable for a 2002 car. Today this unit arrived so I fitted it to the car. I had to change the coding from 00104 to 00004 initially as I was getting a coding error - presumably related to the fact that this car has a magnetic clutch on the AC compressor, but after that was done I ran all the VAGCOM tests and checked measuring blocks etc and all appeared to be OK, but on this unit the ECON light was on solidly. I checked for fault codes and this unit came up with:
    2 Faults Found:
    00819 - High Pressure Sensor (G65) 29-00 - Short to Ground
    01592 - Air Quality Sensor (G238) 57-00 - Electric Circuit Failure
    Anyway, I stopped there as I am bamboozled about a number of things. Why do both units operate the entire system without issues apart from neither will actually activate the air con compressor? Is the coding correct on both of these units? When coding, what does the Shop# mean on VAGCOM? Why do the fault codes from the 2nd unit not appear with the original one? And finally, does the pre-post 2002 issue with these units actually relate to allroads on not?
    Thanks for reading my very long post, and if you have any advice to offer - I am all ears! Thanks in advance!
  2. Re: 2002 Audi allroad 2.5tdi HVAC issues
    Aug 2008
    Isle of Skye
    Hello, just to add some more info to this, I spent some more time this afternoon checking both control units again, and had the same results as yesterday. The coding for both units is definitely correct, it is very self explanatory really.
    The original unit 4B0 820 043 H still gives the fault code: 01582 - Signal for Coolant Temperature 30-00 - Open or Short to Plus
    The new unit 4B0 820 043 AQ still gives the following 2 fault codes: 00819 - High Pressure Sensor (G65) 29-00 - Short to Ground & 01592 - Air Quality Sensor (G238) 57-00 - Electric Circuit Failure, ALSO the ECON light is on permanently on the dash.
    I am almost 100% sure that these faults on the 2nd unit are genuine as when I interrogate those sensors in VAGCOM the results are unusual, but with the original unit the measuring blocks in VAGCOM do not exist to interrogate either of those sensors.
    So, assuming the fault codes are correct, then according to the post below of another fellow who had the exact same faults in a 2002 A6, then hopefully changing the G65 sensor should get the AC working again (assuming there is any gas in the system - this car had sat for 2 years before I bought it!). Actually, thinking about that, if there was no gas in the system, would that trigger the same G65 code I am seeing?
    A6 2002 1.9tdi 130ps - Air Con Failure
  3. Re: 2002 Audi allroad 2.5tdi HVAC issues
    Aug 2008
    Isle of Skye
    Another update, just back from the car - I removed the G65 pressure sensor, it was split where the metal is swaged on to the plastic 3 pin connector end and quite definitely broken, I guess that all the gas in the system probably escaped past the split in this sensor. I then remembered that I had a DIY air con pressure tester. I connected it up to the low pressure port and there was zero psi of gas pressure there. So, I will be buying a new sensor and getting a re-gas done. The part number on my old sensor is 8Z0 959 126 DRH (not sure if the DRH has anything to do with the part number though). After lots of internet searching I am not sure what part number i need for the new sensor as this part was long ago superseded. I *think* that the Hella part 6ZL 351 028-401 should be correct, but I do not want to order one until I have it confirmed as I have read of many people struggling to get the correct replacement part here!
    If anyone can confirm the correct part number for me it would be greatly appreciated.
  4. Re: 2002 Audi allroad 2.5tdi HVAC issues
    Nov 2016
    Swindon
    13 Post(s)
    The pressure sensor P/N should be 8E0959126, Hella 6ZL 351 028-401, Denso DPS32002... But I think is called G65, G56 is the interior sensor.
  5. Re: 2002 Audi allroad 2.5tdi HVAC issues
    Aug 2008
    Isle of Skye
    Thank you. You are correct, it is G65, I made a typo above!
  6. Re: 2002 Audi allroad 2.5tdi HVAC issues
    Aug 2008
    Isle of Skye
    Quote Originally Posted by Chema.RB View Post
    Just a little update. I purchased a DENSO DPS32002 but unfortunately it does not fit - the design of the threaded end is completely wrong and you cannot even get it on to the thread on the condenser. I will return that and try to get the Hella part next.
  7. Re: 2002 Audi allroad 2.5tdi HVAC issues
    Aug 2008
    Isle of Skye
    Quote Originally Posted by skyegtb View Post
    Just a little update. I purchased a DENSO DPS32002 but unfortunately it does not fit - the design of the threaded end is completely wrong and you cannot even get it on the the thread on the condenser. I will return that and try to get the Hella part next.
    Just to conclude this. I received the Hella part 6ZL 351 028-401 in the post today. Fitted it to the car then topped up the refrigerant and now have working AC again. Yay! The fault code about the air quality sensor does not seem to affect the operation of the AC so I will leave it as it is.
  8. Re: 2002 Audi allroad 2.5tdi HVAC issues
    Nov 2016
    Swindon
    13 Post(s)
    Great to know! Do you have any pictures of the pressure sensors?
  9. Re: 2002 Audi allroad 2.5tdi HVAC issues
    Aug 2008
    Isle of Skye
    Hi, here are some pictures. Firstly of the 2 different control units. The new unit 'AQ' had a different front bezel on it than the one fitted to the car, so I had to swap these over. The new one was broken anyway so this was for the best. The other pics show the Denso sensor that didn't fit and the new Hella sensor, also a few pics of the original and it's damage.
  1. Coolant Level in Reservoir Audi Allroad 2002 AKE 2.5TDI
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-11-2013, 04:00 PM
  2. Bleeding Fuel System on Audi Allroad 2002 2.5TDi AKE
    Last Post: 25-03-2012, 02:27 PM
  3. Replacing Air Con Compressor on 2002 Audi Allroad 2.5TDI AE
    Last Post: 18-03-2012, 06:44 PM
  4. 2002 Audi A6 Allroad 2.5tdi V6 Engine Knocking Noise
    By Paul_Bishop in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-05-2011, 02:49 PM
  5. Audi allroad 2.5tdi 2002 weird electrics
    By ALLRO in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-04-2010, 09:41 AM
