Thread: Golf 5 2004 Steering Torque Sensor (G269)
  1. Golf 5 2004 Steering Torque Sensor (G269)
    Jan 2017
    Albania
    Hi guys, My first post in this forum
    I need some help here please
    I have Golf5 1.6fsi, it is giving me a problem with the Steering Torque Sensor (G269). Steering Assist stops working. After I make clear DTC it works for a moment and stops working again.
    For more info I have a detailed log and some screenshots I made when diagnosing it with vcds.
    Full Log
    Code:
    Saturday,14,January,2017,14:00:53:01249VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 16.8.3.1 (x64)
    Data version: 20161010 DS267.0
    www.Ross-Tech.com
    VIN: WVWZZZ1KZ4W025978   License Plate: LA9797A
    Mileage: 285610km-177469mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ4W025978   Mileage: 285610km-177469miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine        Labels: 03C-906-056-BAG.lbl
       Part No SW: 03C 906 056 B    HW: Hardware No
       Component: MED9.5.10       G00 5401
       Revision: 00000000    Serial number: VWZ7Z0C8700921
       Coding: 0000072
       Shop #: WSC 01392 785 00200
       VCID: 224C26C3FDCB10528A-8076
    8 Faults Found:
    18726 - Fuel Pressure Regulator Valve (N276)
                P2294 - 004 - Open Circuit - MIL ON
    17439 - Intake Manifold Tuning Valve (N316)
                P1031 - 008 - Setpoint Not Reached - Intermittent - MIL ON
    17912 - Intake Air System
                P1504 - 008 - Leak Detected - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
                P0300 - 001 -  - MIL ON
    16685 - Cylinder 1
                P0301 - 001 - Misfire Detected - MIL ON
    16688 - Cylinder 4
                P0304 - 001 - Misfire Detected - MIL ON
    18354 - Control Module 1 for Coolant Fan
                P1946 - 004 - Defective - Intermittent
    16825 - EVAP Emission Control Sys
                P0441 - 002 - Incorrect Flow
    Readiness: 0010 0001
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0019074
       VCID: 3A7CFEA3755B7892B2-806E
    No fault code found.
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No: 1K0 820 047 CB
       Component: Climatic PQ35   060 0201
       Shop #: WSC 00000 000 00000
       VCID: 66C47AD351632C7226-8032
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 1K0 937 049 L    HW: 1K0 937 049 L*
       Component: Bordnetz-SG 1.0 H29 0701
       Revision: 00029000    Serial number: 00000000279679
       Coding: E58D0F0600041800001400001400000000
       VCID: 3878E4AB4B576A8244-806C
       Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
       Component: Wischer 250108 021  0501
       Coding: 00038805
       Shop #: WSC 00000
       Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 002  0505
       Coding: 00217125
       Shop #: WSC 00000
    8 Faults Found:
    01520 - Rain and Light Recognition Sensor (G397)
                008 - Implausible Signal
    02394 - Parking Light Left Front (M1)
    01502 - Bulb for Rear Fog; Left (L46)
    01500 - Bulb for Fog-Lamps; Right (L23)
                010 - Open or Short to Plus
    01064 - Terminal 58d; Interior Dimming
    00979 - Lamp for Low Beam; Right (M31)
                010 - Open or Short to Plus - Intermittent
    01496 - Bulb for Fog-Lamps; Left (L22)
    00526 - Brake Light Switch (F)
                008 - Implausible Signal - Intermittent
    Address 15: Airbags        Labels: 1K0-909-605.lbl
       Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
       Component: 06 AIRBAG VW8   022 0500
       Revision: 04022000    Serial number: 0033FD0521TS
       Coding: 0012342
       Shop #: WSC 01371 785 00200
       VCID: 2A5CCEE385FBC812C2-807E
       Subsystem 1 - Serial number: 6332MSME6C040401
       Subsystem 2 - Serial number: 6342MSME66750401
       Subsystem 3 - Serial number: 6351HSME3B057300
       Subsystem 4 - Serial number: 6361HSME12067600
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 012 0030
       Coding: 0000022
       VCID: 3068DC8BA327B2C20C-8064
    Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       Part No: 1K0 920 850 K
       Component: KOMBIINSTRUMENT VDD 3550
       Coding: 0001101
       Shop #: WSC 80093 222 69422
       VCID: 2F6ADFF7BE19AD3A15-807A
    1 Fault Found:
    00003 - Control Module
                014 - Defective
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 2100103A235B23
       Coding: 3D3F0340070002
       VCID: 275A37D796E9F57ADD-8072
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO                3550
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0115
       Coding: 0000052
    1 Fault Found:
    00943 - Heated Exterior Mirror; Driver Side (Z4)
    Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
       Part No: 1K1 909 144 E
       Component: EPS_ZFLS Kl.1       1202
       VCID: 2D56C5FFB415DF2A27-8078
    2 Faults Found:
                014 - Defective - MIL ON
                007 - Short to Ground - Intermittent
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 C
       Component:    KSG              0545
       Coding: 00E802087F2D8404084F0100
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Component: Tuersteuergeraet 09 0102
       Coding: 0000052
       VCID: 316ED98FA82DBBCA03-8064
    Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
       Part No: 1K0 035 186 G
       Component: Radio BNO           0013
       Coding: 0020200
    2 Faults Found:
    01044 - Control Module Incorrectly Coded
                000 -  -
    00856 - Radio Antenna
                011 - Open Circuit
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 C
       Component: Tuersteuergeraet 05 0108
       Coding: 0000016
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 C
       Coding: 0000016
    End-------------------------(Elapsed Time: 02:20)--------------------------
    Partial Log
    Code:
    Saturday,14,January,2017,14:08:22:01249VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    www.Ross-Tech.com
    Control Module Part Number: 1K1 909 144 E
      Component and/or Version: EPS_ZFLS Kl.1       1202
               Software Coding: 0000000
                Work Shop Code: WSC 00000 000 00000
    2 Faults Found:
    Address 44: DTCs clearedTuesday,17,January,2017,11:38:39:01249
    www.Ross-Tech.com
    2 Faults Found:
    00573 - Steering Torque Sensor (G269)
    Tuesday,17,January,2017,11:39:52:01249
    www.Ross-Tech.com
                    Address 44: Steering Assist  (1K1 909 144 E)
    11:39:50 Group 001
      20.0°C  Temperature Output Stage
      0.000 Nm  Steering Torque (G269)
      0 /min  Rotor Speed of Power Steering
      N/A
    11:39:50 Group 002
      8.50 V  Relay Voltage
      11.90 V  Battery Voltage (Terminal 30)
      5.10 V  Sensor Supply (G269)
      0  Battery since Term. 30 Recogn.
    11:39:50 Group 004
      6  System Status
      Term 15 On  Status Terminal 15
      Relay OFF  Relay Condition
      N/A
  2. Re: Golf 5 2004 Steering Torque Sensor (G269)
    134 Post(s)
    2012 Post(s)
    That fault normally means a new steering rack.
  1. Steering torque sensor
    By phil miller in forum VCDS - Help Requests
    Last Post: 18-11-2017, 07:51 PM
  2. Question Golf 1.6 FSi 2004 Nox sensor fault
    By Golf 1.6FSi 04 in forum Golf MK5 - 2004 - 2009
    Last Post: 28-05-2015, 12:32 AM
  3. Please Help Steering torque sensor issues
    By leecool in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-04-2015, 12:28 PM
  4. Replies: 11
    Last Post: 25-03-2013, 08:41 PM
  5. Iat Sensor On 1.9tdi 2004 Golf Mk5
    By bigshorts1 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-05-2008, 11:16 PM
