Thread: A6 Avant HVAC Blows Cold Air when Engine on low revs or Idle
Results 1 to 10 of 17
  1. A6 Avant HVAC Blows Cold Air when Engine on low revs or Idle
    Dec 2016
    Suffolk
    firstly Apologies if this has been asked before but after trolling thru endless back forum posts could not find an answer.
    I am fairly new to Audi's and have had this one for only a month or so. When i first had car the heater was very intermittent, shortly afterwards it gave up completely only blowing cold air regardless of what settings were on. After extensive research and getting nowhere i took it to my local garage who bled the cooling system and re-filled using a Vac system to ensure no air locks. After that heater worked fine blowing lovely hot air etc but as soon as you drop revs down or go to idle the heat diminishes to just about nothing! I am now wondering whether this is right. Any of you out there have any suggestions as what to try next or is this just the way the HVAC works?
  2. Re: A6 Avant HVAC Blows Cold Air when Engine on low revs or Idle
    Pembrokeshire
    22 Post(s)
    welcome to the forum. a few car details wouldnt go amiss, engine type etc, but it sounds like you might have a water pump problem.
  3. Re: A6 Avant HVAC Blows Cold Air when Engine on low revs or Idle
    Dec 2016
    Suffolk
    Apologies for not giving car details etc. its a 2006 A6 Avant 2.0l Tdi S line with 90,000 miles on the clock. What is the best way to check if it is the water pump?
  4. Re: A6 Avant HVAC Blows Cold Air when Engine on low revs or Idle
    Pembrokeshire
    22 Post(s)
    engine running, small pipe into top of coolant resevoir, should be a constant flow of coolant. if not, needs pump. when was it last changed, should have been 30 odd thousand miles ago when the belt was done ??
  5. Re: A6 Avant HVAC Blows Cold Air when Engine on low revs or Idle
    Dec 2016
    Suffolk
    I dont think the pump was changed then, The belt is due to be checked before the end of Dec
  6. Re: A6 Avant HVAC Blows Cold Air when Engine on low revs or Idle
    Pembrokeshire
    22 Post(s)
    you dont check a belt, either change it or not change it. only way to check it is to remove and inspect, and only a fool would then re fit it. best to get a new belt and pump, job done properly.. by the way, end of dec was a couple of weeks ago
  7. Re: A6 Avant HVAC Blows Cold Air when Engine on low revs or Idle
    Dec 2016
    Suffolk
    I should add that the car is a lefthand drive which i brought as i spend alot of time overseas, ive driven it for 1500 miles bringing it back to UK and the temp gauge was rock steady at 90deg all the way, i would have thought that it would have had temp fluctuations during that journey if the water pump was not working
  1. Question Engine Rattling when idle & at low Revs
    By ebypatel in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-11-2015, 02:50 PM
  2. Replies: 1
    Last Post: 03-09-2013, 12:54 PM
  3. Engine shuddering at idle and low revs
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-01-2011, 07:15 PM
  4. Engine fan comes on at cold start, heaters blowing cold air when idle
    By walsie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2010, 07:26 PM
  5. only blows cold air
    By rd200dxe in forum Toledo
    Last Post: 29-12-2009, 10:52 PM
