Thread: Reversing Light Fuse
Results 1 to 9 of 9
  1. Reversing Light Fuse
    Aug 2008
    I have been fitting a pair of DRL LED lights as an improvement to the poor single reversing light,to my 2.0ltr TDI Highline Plus Estate
    I have fitted them under the ledge adjacent to the number plate lights, and the look quite neat.
    My problem is I have Blown a fuse, and despite looking at my Haynes Manuel, which shows the 5A fuse in the left hand dashboard
    position I remove the cover but no fuses there
    Can anyone enlighten me please
    Thanks Mike
  2. Re: Reversing Light Fuse
    Dec 2014
    Bedford
    42 Post(s)
    Tried the right side of dash?
    Sent from my SM-G900F using Tapatalk
  3. Re: Reversing Light Fuse
    Aug 2008
    Quote Originally Posted by FLAPPERJACK76 View Post
    Thanks, I have opened R H Side Cover but I am not sure which fuse ,
    Do I just check all fuses,
    Cheers Mike
  4. Re: Reversing Light Fuse
    Sep 2008
    SE London
    Check fuse holder "C" which is under the left (as you face the rear of car) dash cover. 24 is a 5A, and 30 is a 15A (this is marked as for trailer on my fuse booklet that matches my '06MY)
    Most voltages to external lamps are controlled by electronic modules. These have a fail feature that switches off the supply if a fault condition exists, such as short circuit or an unusual load such as extra bulbs added to a circuit taking extra current.
    If you don't have access to VCDS to see whether such a fault condition has been stored, try disconnecting the connections you've made,
    then disconnecting the battery and tying the lead clamps together to perform a "hard reset". Leave like that for say 10 minutes, then re-connect battery. Has your normal OEM reverse light function returned?
  5. Re: Reversing Light Fuse
    Aug 2008
    Thanks RichardSEL
    I have checked 5 and 15Amp fuses which seem to be OK
    So I'll try disconnecting battery etc, or try to find someone handy with VCDS
  6. Re: Reversing Light Fuse
    Jul 2007
    glasgow
    35 Post(s)
    does the Passat have a convience unit like my a6 , that has to be recoded for LED lights ?
  7. Re: Reversing Light Fuse
    Aug 2008
    Hi Niall
    Not sure about convience unit, but I fitted some superbright eagle eye lights which were unbelievably
    bright and I was very pleased with,and no dashboard display problems, but they started to fail. and I decided to replace them with more stylish
    Superbright DRLights, but during the changeover I must have short circuited the wiring
    I was hoping it was a blown fuse
  8. Re: Reversing Light Fuse
    Aug 2008
    Hi Richard SEL
    Thanks Just sorted my problem, It's been a few weeks as I have had a Cateract Op, but as you suggested a 'Hard Reset' did the trick,
    and the dashdoard error has gone, What would that cost at the Dealership £100 ???
    Thanks again
    Mike
  9. Re: Reversing Light Fuse
    Sep 2008
    SE London
    £132 +VAT if they charge only one hour for a VAS scan -- usually they charge two hours on the basis that "they don't know so we can charge what we like".
    I only charge £20.
    So send your cheque, postal order, or moneygram to:
    VW are a Bunch of Cheeep Rip Off Merchants (IMO)
    c/o Dr Martin Winklehorn
    The Federal Pennitentary
    Somewhere Miles from Nowhere
    Never to be Seen Again
    United States of America
  1. reversing light
    By Don tucker in forum Golf MK6 - 2009 - 2013
    Last Post: 03-11-2014, 05:39 PM
  2. Rear Light plug - which is reversing light position?
    By ming in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-07-2010, 07:20 PM
  3. reversing light
    By stringman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-02-2009, 06:44 PM
  4. reversing light
    By gixxerk4600 in forum Audi A3 - Archive Topics
    Last Post: 20-11-2008, 09:02 PM
  5. Polo 2004 reversing light fuse(s)
    By MarkWayman in forum Polo - Derby - Lupo - Fox
    Last Post: 24-01-2008, 05:30 PM
