Thread: Starting mortor making funny noise !!!
  1. Lightbulb Starting mortor making funny noise !!!
    hampshire, portsmouth
    Hiya people
    I seem to have a money pit of a car at the moment
    Since i have sorted (well fingers crossed) the faults found on my golf gti mk4. The starting motor has been making strange noises after i start her up. She actually starts up fine its just the noise that bothers me shortly afterwards.
    What has led up to this problem was car would intermittently loose power, so every time i was stalling i was starting the car up putting more strain on the starting motor i think ???
    Any ideas as i don't think it needs replacing.
    Vicky
  2. Re: Starting mortor making funny noise !!!
    Aug 2007
    Northern Ireland
    Well Vicky, this is becoming a regular occurance isnt it
    Could be a build up of dirt (dust from the clutch usually) causing the bendix to stick, if so then just need the motor removed, cleaned & lubricated and refitted.
    Probably 50-80 quid or so
    Pete
    52 plate Golf GT TDi
  3. Re: Starting mortor making funny noise !!!
    134 Post(s)
    2009 Post(s)
    Starter motor noise just after release of the key is a major issue on modern VAG products. It started after VW remove the pinion guide bearing from the box and made the starter self supporting and even some of the older design starters do it to. It rarely causes a breakdown initially so live with it until the starter fails.
  4. Re: Starting mortor making funny noise !!!
    Quote Originally Posted by mobitune View Post
    Pete
    Hullo pete fancy meeting you here !!!
    arrrrrrrr me think mrs golf is going to cost me
    Is there a way you can do that yourself or is it a job for the professionals ?? also getting off the subject slightly (((sorry))) since the first mechanic fitted the new cat and exhaust poorly. There is a slight blow at the top of the exhaust would this cause the car to miss fire slightly until its sealed ??? as it judders ever so slightly then misfires ((not badly but ever so often you feel it))
    Thankyou once again
    Vicky
  5. Re: Starting mortor making funny noise !!!
    HI CRASHER
    Thankyou for that, i don't feel its necessary either to replace it yet like the old saying if its not broke don't fix it LOL
    Seems to be one big fault this car that's the way I'm feeling at the moment grrrrr. Well anyway maybe a clean will do the motor ??? guess work all the way isn't it
    Vicky
  1. 2002 B5.5 1.8T making shh shh noise!
    By RobBentley in forum Passat - Archive Topics
    Last Post: 23-08-2007, 06:49 PM
  2. MK4 Golf GTi - Funny whirring noise
    By rickgti in forum Golf MK4 - 1999 - 2004
    Last Post: 16-07-2007, 11:14 PM
  3. vw golf making loud noise when turning and also when travelling on uneven roads
    By madz in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-05-2007, 06:40 PM
  4. Funny noise from my Touran
    By Touran 75 in forum Touran - Sharan - Caravelle
    Last Post: 09-03-2007, 11:35 PM
  5. Brakes making whistling noise
    By thecoolalhambra in forum Passat - Archive Topics
    Last Post: 18-09-2006, 03:11 PM
