Thread: diesel fumes inside cabin
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: diesel fumes inside cabin
    Sep 2020
    Warrington
    Had exactly the same issue, it was the exhaust gasket at the back of the engine between the turbo and DPF filter at fault. To test it, when cold spray some fairy liquid/water around the V-Clamp, you will see it bubbling away.
    I did the job myself twice, first time used a cheap gasket which didn't work so id advise to obtain gasket from VW.
    You need raise the car on a set of ramps and remove DPF supporting nuts at the back of the engine to allow the DPF to move for access, disconnect the V band clamp, move the DPF out of the way, remove and replace the gasket.
  2. Re: diesel fumes inside cabin
    Oct 2017
    London
    12 Post(s)
    The exhaust joining section clamps also corrode and fall off. This allows fumes into the cabin. Potentially lethal.
  1. Exhaust fumes in cabin
    By Dutch Paddy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-02-2018, 09:40 PM
  2. Sharan; Fumes in cabin
    By rbraddley in forum Touran - Sharan - Caravelle
    Last Post: 28-02-2011, 01:48 PM
  3. Fumes in cabin
    By Countylad1970 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-12-2010, 09:15 PM
  4. Question Fumes in Alhabra cabin
    By alhambra130 in forum Alhambra
    Last Post: 27-02-2010, 07:57 PM
  5. Question Fumes in cabin of A4 Tdi
    By sponger in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-06-2008, 10:10 AM
