Thread: Electical and Relay Questions
  1. Unhappy Electical and Relay Questions
    doodbrie Guest
    I have an Audi Coupe H reg 2000E 8V and hopefully someone can point me in the right direction.
    My Audi past its MOT but on the way home it decided to self destruct ie smoke coming from the dash - result a dead car. (Result of a leaky screen drivers side)
    A so called Local Auto Electrician confidently told me he could fix it. To cut a long story short he made a complete mess of the job and now I am stuck well and truly with wires hanging out beneath the Drivers side and have not got a clue how to over come this problem but am determined to fix it as the Audi is worth saving.
    Here goes. The fuse board in the Engine compartment was changed but the Relays were taken out but I have no idea which one goes where ie which position on the board.
    These are the relays I have 213,214,272,229,292,215,285309,76, plus 2 taller black relays with no numbers on them.
    Can any one tell me what each one does and what position it goes on the Fuse board (I know there is an Auxilliary one under the Drivers glove box as well)
    Also coming from the Immobillizer (underneath the Steering there is a black wire with No 4 on it going no where (any ideas where this is connected to?
    At the moment when I turn on the Ignition the computer beeps once then 3 times the screen flashes a petrol sign then a oil sign which stays on (have checked the oil and it is up to the correct level. The car turns over but am getting no spark to the Plugs.
    The car used to start and run with absolutely no problems, I only have one Ignition key.
    I would really appreciate any and all advice on how to solve this problem.
    Finally I have been looking on the Audi forum but have not found anything that might help with my problem.
    Any and all advice would be really appreciated.
    doodbrie
  2. Re: Electical and Relay Questions
    134 Post(s)
    2007 Post(s)
    Can you do a list of all those with the VW part number off each one at the side?
  3. Thumbs up Re: Electical and Relay Questions
    doodbrie Guest
    Hi Crasher
    At the moment I havent got the Relays as they are on order but as soon as I get them I will post the part numbers. It will probably be about 5th / 6th October before I can reply to you.
    Hope you or anyone else can help.
    regards
    doodbrie
  4. Re: Electical and Relay Questions
    Gwent
    I had an intermittent cutting out problem and the occasional beep/oilcan symbol coming up on the autocheck. Like yours, there was no problem with the oil. Mine turned out to be an earth wire breaking off at the back of the connector.
    This was on my 20v, the earth was at the back of the inlet manifold.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  5. Wink Re: Electical and Relay Questions
    doodbrie Guest
    Hi Scotty
    Thanks for the Tip, will check mine to see if it`s the same problem.
    The sooner I get my Relay`s delivered the sooner Crasher hopefully can help me?
    Keep the Tips coming guys.
    Regards
    doodbrie
  6. Red face Re: Electical and Relay Questions
    doodbrie Guest
    Hi Crasher
    The relays have at last arrived, am not sure if I have them all but here is a detailed list of what I have and all the relevant numbers on them.
    214
    89 9512
    443 951 253K
    215
    89 9521 SHO
    443 951 253L
    Slot for fuse on top of relay
    213
    89 9511
    70A 12V SHO
    443 951 253 J
    229
    SME 12V
    431955 531
    SIEMENS SWK 1 637 (17007 In White letters on side)
    292
    Hella 12V
    35B
    004 885 02
    443 951 307B
    236
    EAP EO 605
    443 955 532A
    2RL 12- (719 34 In white letters on side)
    76
    443927 826
    89 71 44
    SHO 12V 16A
    10 Amp fuse on top
    285
    Large black relay with no number
    7543 2189
    Small black relay with no number
    Hella LKE 12V K13
    SKG 004 079-01
    4439 19 469
    12V 55W
    These relays weresent as a set apparently but there may be realys missing but am not sure.
    If you can identify what each one is for and what position they go on the fusebox either in the Engine compartment or under the Drivers side glove box it would be really helpfull.
    Also am still trying to figure out what the Number 4 wire goes to from the immobillizer?
    Best regards
    doodbrie
    Thanks for your advice so far.
    Best regards
    doodbrie
  7. Re: Electical and Relay Questions
    134 Post(s)
    2007 Post(s)
    This is the best I can do,
    214
    89 9512
    443 951 253K
    Changed to part number 8D0 951 253 A on 31/12/98.
    Used for;
    Rear fog lights in relay location 1
    GB dim dip driving lights code 373 or 1
    Cooling fan code 373 or 2
    Injector cooling fan code 373 or 3
    Also used for air conditioning, basically a 35 to 40 amp general purpose four pin relay.
    215
    89 9521 SHO
    443 951 253L
    Fuel pump relay for AAD engine, relay location 10
    213
    89 9511
    70A 12V SHO
    443 951 253 J
    Changed to 8D0 951 253 on 01/10/2000 and then to 7M0 951 253 A on 01/01/2006. Used for;
    Contact relief (X) relay code 370 or 5
    229
    SME 12V
    431 955 531
    Changed to 321 955 531 A on 30/06/1978 (!!!) and the n 191 955 531 on 31/12/1988.
    Used for intermittent wash wipe in relay location 9
    292
    Hella 12V
    35B
    004 885 02
    443 951 307B
    Buzzer in relay location 2
    236
    EAP EO 605
    443 955 532A
    Changed to 443 955 532 C on 31/10/89
    Used for fan run on control, location 3
    76
    443 927 826
    89 71 44
    SHO 12V 16A
    10 Amp fuse on top
    Changed to 8A0 927 826 31/08/92
    Used for ABS dual relay
    285
    7543 2189
    Hella LKE 12V K13
    SKG 004 079-01
    443 919 469
    12V 55W
    Changed to 443 919 469 A on 15/11/1988
    Used for headlight checking on models with check package
  1. Relay trouble.
    By wid77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-05-2009, 05:19 PM
  2. Relay Box
    By john Mc Grath in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-12-2007, 12:52 PM
  3. 109 relay
    By kow in forum Audi A3 - Archive Topics
    Last Post: 01-12-2007, 05:23 PM
  4. audi a3 109 relay
    By kow in forum Archive posts
    Last Post: 27-08-2007, 08:15 AM
  5. wiper relay
    By alanled in forum Touran - Sharan - Caravelle
    Last Post: 22-01-2007, 11:21 PM
