Thread: Throttle body
  1. Throttle body
    Nov 2013
    leicester
    hi
    i had the following error
    7859 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 00 [039] - Implausible Signal
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    I changed the throttle body for a brand new one and did the adaption but i still get the above error
    can anyone help out
    Danny
  2. Re: Throttle body
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Dont forget the fault could be caused by the wiring to it.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Throttle body
    Nov 2013
    leicester
    Quote Originally Posted by Alan02 View Post
    Hi
    thanks for the reply how would i go about checking the wired
  4. Re: Throttle body
    Aug 2014
    Slovenia
    What is your engine code and car year?
    AUDI A4 B8 2.0TDI 2010 100kW CAGB
  5. Re: Throttle body
    Nov 2013
    leicester
    Quote Originally Posted by turbozob View Post
    hi
    engine code is CAGAyear 2008
    thanks
  6. Re: Throttle body
    Aug 2014
    Slovenia
    I sent you drawings in your inbox.
  7. Re: Throttle body
    135 Post(s)
    2040 Post(s)
    I think that code refers to the V183's variable intake manifold position sensor G513 rather than the V157 flaps G69 sensor. The V157 does not need adapting. I wish these codes all had the relevant SDC code included to prevent confusion like this, the Ross Tech explanation is
    18447 (P2015) - Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal
    but the ELSA diagram annotates two parts like this
    "Variable Intake Manifold Motor V183, with variable intake manifold falp position sender G513"
    and
    "Intake Manifold Flap Motor V157 with throttle valve potentiometer G69"
    so which one do you choose????
  8. Re: Throttle body
    Nov 2013
    leicester
    are there any tests i can run via vcds to see if the v183 motor is work correctly ?
    and
    so which on do you choose????
  9. Re: Throttle body
    135 Post(s)
    2040 Post(s)
    Yes, in output tests
  1. Throttle body
    By Mikeb8 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-09-2015, 09:21 PM
  2. Clean throttle body and perfom Throttle Body Alignment (TBA) - big job?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2013, 09:50 PM
  3. A6 Throttle Body??
    By K.Sturgeon in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-08-2010, 06:46 PM
  4. Please Help where is the throttle body
    By bigdavehep in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-01-2009, 04:47 PM
  5. Throttle body
    By swerve in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2008, 05:16 PM
