Thread: Vw sharan dmf weld up
  1. Re: Vw sharan dmf weld up
    Pembrokeshire
    22 Post(s)
    well, lets look at the question, i want to weld up my dmf, what clutch should i fit, who the heck is going to be able to answer that. either fit a new dmf or if you really must, a smf conversion , which is highly un recommended. if you want a clutch to fit a dmf then you will need to trawl the web and or parts books to find it.
    most people use this forum as i do, looking only at new posts, so which section its in is irrelevant. i saw this question pop up a while back and though, no one will answer that, but i bet i end up having to in a few days, so yeah, crystal balls and all that
  2. Re: Vw sharan dmf weld up
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Here you go - single mass flywheel kit, by the time you've welded and balanced the old flywheel you could probably have spent the same time / money and just fitted this. Reckon it'll be dog rough, either welded or witn SMF though.
    Darkside Developments - Valeo 1.9 TDi 6 Speed 02M Single Mass Flywheel and Clutch Kit (SMF)
  1. Best cold weld/ sealing solution
    By 123ashleyp in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-05-2015, 07:18 PM
  2. Can anyone weld stainless on here and have some ramps?
    By mne666 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-10-2012, 08:32 PM
  3. DMF on its way out.
    By veedubit in forum Bora - 1998 - 2005
    Last Post: 04-10-2009, 10:26 PM
  4. VW Golf TDI MK3 clutch pedal weld broke
    By typolee in forum Golf MK3 - 1993 - 1999
    Last Post: 09-07-2009, 10:09 AM
