Thread: Vw sharan dmf weld up
  1. Vw sharan dmf weld up
    Oct 2012
    reykjavik
    Hey people, not been around for a while.
    Basically my sharan has been perfect.... Weird right?
    Anyway im getting judder under load and been through everything it could possibly be so the only thing left is a failing dmf, it has been rattling when cold so it needs doing!
    Im an engineer, welder, fabricator so im just going to weld up my dmf, re balance it and fit a sprung clutch.
    My problem is, what clutch plate fits that has the springs in?
    Im with 2002 7m pd115
    Any input would be awesome, by the way, my sharan is on 400k km and still going strong, just cant justify the cost of a new dmf kit on this old bus and its basically used just for the school run.
    Craig
    And merry Christmas
  2. Re: Vw sharan dmf weld up
    Oct 2012
    reykjavik
    Bump
  3. Re: Vw sharan dmf weld up
    nottinghamshire
    the touran section seems real quiet maybe we should pretend we have golfs as there section is booming busy
    ask the same qiestion there i bet you get a reply quicker......
  4. Re: Vw sharan dmf weld up
    Pembrokeshire
    22 Post(s)
    well, lets look at the question, i want to weld up my dmf, what clutch should i fit, who the heck is going to be able to answer that. either fit a new dmf or if you really must, a smf conversion , which is highly un recommended. if you want a clutch to fit a dmf then you will need to trawl the web and or parts books to find it.
    most people use this forum as i do, looking only at new posts, so which section its in is irrelevant. i saw this question pop up a while back and though, no one will answer that, but i bet i end up having to in a few days, so yeah, crystal balls and all that
  5. Re: Vw sharan dmf weld up
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Here you go - single mass flywheel kit, by the time you've welded and balanced the old flywheel you could probably have spent the same time / money and just fitted this. Reckon it'll be dog rough, either welded or witn SMF though.
    Darkside Developments - Valeo 1.9 TDi 6 Speed 02M Single Mass Flywheel and Clutch Kit (SMF)
  1. Best cold weld/ sealing solution
    By 123ashleyp in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-05-2015, 07:18 PM
  2. Can anyone weld stainless on here and have some ramps?
    By mne666 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-10-2012, 08:32 PM
  3. DMF on its way out.
    By veedubit in forum Bora - 1998 - 2005
    Last Post: 04-10-2009, 10:26 PM
  4. VW Golf TDI MK3 clutch pedal weld broke
    By typolee in forum Golf MK3 - 1993 - 1999
    Last Post: 09-07-2009, 10:09 AM
