Thread: Polo 2003 1.2 Pertol Engine cover
Results 1 to 10 of 10
  1. Polo 2003 1.2 Pertol Engine cover
    My daughter has just bought a 2003 1.2.polo and the engine cover is loose and rattles. How does the cover come off. i cant find any screws, tried pulling and it wont lift.
  2. Re: Polo 2003 1.2 Pertol Engine cover
    134 Post(s)
    2007 Post(s)
    Petrol or diesel?
  3. Re: Polo 2003 1.2 Pertol Engine cover
    Sorry its Petrol..
  4. Re: Polo 2003 1.2 Pertol Engine cover
    134 Post(s)
    2007 Post(s)
    It pulls off but it takes quite a lot of force.
  5. Re: Polo 2003 1.2 Pertol Engine cover
    ok cheers.. i will try again, worried about the plastic snapping...
  6. Re: Polo 2003 1.2 Pertol Engine cover
    there's rubber mountings that would come out before it snaps
  7. Re: Polo 2003 1.2 Pertol Engine cover
    Jun 2008
    I have exactly the same problem on my 2000 W reg polo, can anyone tell me how to take the cover off please?
  8. Re: Polo 2003 1.2 Pertol Engine cover
    134 Post(s)
    2007 Post(s)
    Which engine code?
  9. Re: Polo 2003 1.2 Pertol Engine cover
    Mar 2009
    Melton Mowbray
    Just pull them i have a 1.2 petrol polo and i thought mine was going to break but i just gave it a good pull and it came off! Hope this helps.
  10. Re: Polo 2003 1.2 Pertol Engine cover
    Sep 2008
    Bristol/Bath/Swindon
    just pull it right off... give it force, but be very careful i actually managed to snap the plastic underneith on the front left part......there is 4 rubber seals holding it on.....one on each corner......also on the right hand side you have two small (one smaller than the other) pipes to pull of (yes just pull them) so once you feel all 4 come off lift gently then pull them two as well as the intake on the front right
    hope this helps.....
    Small bit of advice.....super glues works for about 2 months of every day usage if you do manage to snap the plastic on the under side, so dont worry too much if you do break it....bit of super glue does the trick
  1. under engine cover
    By passat57 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-05-2011, 01:16 AM
  2. '03 Polo engine cover
    By MAC in forum Polo - Derby - Lupo - Fox
    Last Post: 24-08-2010, 01:29 PM
  3. New Polo engine cover
    By chapinspain in forum Polo - Derby - Lupo - Fox
    Last Post: 27-02-2008, 02:27 PM
  4. A3 Sportback Engine Cover
    By prolfe in forum Chat - Anything with wheels
    Last Post: 04-02-2008, 09:12 PM
  5. Top engine cover TDI 140
    By Geraldy212 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-05-2007, 03:53 PM
