Thread: P0408-00 fault code - EGR
  1. P0408-00 fault code - EGR
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All,
    I have a Golf 2011 1.6 TDI it has decided to put the MIL lamp on and go in to limp home mode with fault code P0408 - 00 logged
    After a read round this looks like EGR fault costing between £600 > £1000 to sort out (2 days before Xmas)
    Should I remove it and clean it?
    How easy/hard a job is this ?
    Thanks for the helps
  2. Re: P0408-00 fault code - EGR
    133 Post(s)
    1986 Post(s)
    Complete waste of time, it won't work and it will take you around 8 hours to find out as it is bolted to the back of the lower block under the turbo and behind the DPF and driveshaft, you have to disconnect the DPF and move it to the left to gain access, doing this in the air is tough, on the floor-nasty! We do loads of these and TPS outlets always stocked 2 each, they sell that many a day. Avoid recon ones like they have a sexually transmitted disease. I have tried ONE aftermarket version from ECP as an experiment as at trade price it JUST made sense but the jury is out, an original Wahle from from ECP is £490 retail and genuine VW £329.54 so to buy aftermarket you would need your cam profile checking... the cheap aftermarket HASS is what we tried but it retails at £9.55 less than genuine so you would still be a knob to do it. Ignore the recon one, the company that makes them is local to me but are an inter_national joke...
    0 2 0
  3. Re: P0408-00 fault code - EGR
    Dec 2014
    Bedford
    42 Post(s)
    Like Crasher says waste of time. I've changed about 50 of these and there complete crap. The solenoid valve packs up. The cam lever bearing seizes. The cam lever pin falls out and if it survives all of that yeah it might get dirty. Buy genuine it's cheaper and you will have a 2 year warranty on the part. Takes me about 4 hours to replace and that's removing the battery the subframe the steering rack the os driveshaft the dpf and that's with a ramp.
    Sent from my SM-G900F using Tapatalk
    0 2 0
  4. Re: P0408-00 fault code - EGR
    Jan 2009
    Nuneaton England
    6 Post(s)
    WOW - what a job.
    A big thanks for the information guys, much appreciated.
    Crasher you mention cam profile checking?
  5. Re: P0408-00 fault code - EGR
    133 Post(s)
    1986 Post(s)
    Quote Originally Posted by mumutley View Post
    That is a mechanically *******ised play on the term of "having your bumps felt" or "needing your bumps feeling"
    meaning if you paid that for none genuine you would be crazy, I think I must stop posting and drinking but that would stop me posting...
  1. EGR Fault Code....
    By djl78 in forum Golf MK3 - 1993 - 1999
    Last Post: 19-03-2017, 12:57 PM
  2. Please Help EGR Fault Code & Whistling Noise
    By a4newowner in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-02-2013, 02:53 PM
  3. Please Help B6 Passat 2.0 tdi EGr fault. Code P1442 .EML light will not go off!
    By rkm99uk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-07-2012, 07:06 PM
  4. Advice needed on EGR fault code.
    By mickk in forum VCDS - General Questions
    Last Post: 19-08-2010, 12:35 PM
  5. Audi A6 1.9 tdi '04, EGR valve fault code.
    By mike audi a6 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 18-12-2006, 02:10 AM
