Thread: G17 (outside air temp sensor) location help!
  1. G17 (outside air temp sensor) location help!
    Feb 2015
    Somerset
    Got an error on my climate control diagnostics- I get an error for Outside Air (Ambient) Temperature Sensor (G 17). According to everything I can find on a LCR the sensor should be near the passenger foglamp. Instead there is FMIC piping there! I looked in that area and all I have is the wiring for the foglamp that was removed and the wiring for the horns. I do not see the sensor anywhere! Where does the wiring for the G17 start at? I figure if I can find that I can trace to where the previous person that installed the FMIC tucked it away at!
  2. Re: G17 (outside air temp sensor) location help!
    Dec 2014
    Bedford
    42 Post(s)
    Well on a vw golf it's on the nsf so it's probably the same on the leon. If you can't find it take the bumper off there will be 2 wires to it and it will be there on the slam panel loom.
    Sent from my SM-G900F using Tapatalk
  3. Re: G17 (outside air temp sensor) location help!
    2005 Post(s)
    Which Leon?
  4. Re: G17 (outside air temp sensor) location help!
    Feb 2015
    Somerset
    Which Leon?
    2004 Leon Cupra R
  5. Re: G17 (outside air temp sensor) location help!
    2005 Post(s)
    It is down in the left front corner of the bumper under the air intake above the spoiler.
  6. Re: G17 (outside air temp sensor) location help!
    Feb 2015
    Somerset
    found my problem...now to find a connector!
  7. Re: G17 (outside air temp sensor) location help!
    2005 Post(s)
    The sensor is 1J0 919 379 A and costs £31.72, the plug is 1J0 973 702 and costs £3.79 and into this you need 1 double ended yellow repair wire 000 979 019 E which is £5.04 (there are EA and FA gold plated and gold plated with galvanised wire respectively alternatives) and the wires should be sealed in the plug with rubber boot 443 906 102 G which is £6.32. This repair (sans boot) is what has already been done with the other plug. The repaired brown/yellow wire goes into location 1 of the plug and the brown/white into location 2.
  1. Temp sensor location
    By chaz1702 in forum Golf MK5 - 2004 - 2009
    Last Post: 02-06-2016, 06:39 PM
  2. Please Help Temp Sensor location
    By chrismac in forum Golf MK5 - 2004 - 2009
    Last Post: 12-02-2012, 09:31 PM
  3. How To Help, Aircon Information wanted - External air temp sensor location
    By pre_1970 in forum Polo - Derby - Lupo - Fox
    Last Post: 29-08-2011, 06:45 PM
  4. IAT (Intake air temp) and Coolant Temp sensor location
    By yep.its.jay in forum Audi A3 - Archive Topics
    Last Post: 16-03-2009, 10:33 PM
  5. A4 B6 1.8T coolant temp sensor location?
    By lwodrumm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-12-2007, 05:41 PM
