Thread: RIP 2007 Passat? Take a look
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. RIP 2007 Passat? Take a look
    Nov 2016
    Norway
    Hello guys.
    I was driving home the other day with my 2007 Passat 170hk. Suddenly i get this Oil Pressure Warning light. I stop the car immediately and call AAA. They transported the car to a local mechanic. They called me today and said that the car has no oil pressure and it is likely a pump fail. They also said that there were metal shavings under the top filler cap. So i asked them to drain the oil from the car to look for more metal.
    I asked the guy what i should do and he stated that i should not spend any money on repairing the engine because its a gonner!!
    Im so frustratet right now. What can i do? Replace the whole engine? It is not easy to find these 170hp passat engine, usually it is most 140hp.
    Is my engine gone? How long does it take to replace the oil pump? How much does it cost? Or should i just get a new engine?
    Please help me out guys! Merry ******* christmas to me i guess.
  2. Re: RIP 2007 Passat? Take a look
    May 2012
    Everywhere
    308 Post(s)
    You had never heard the oil pump engineering on these is a monstrosity ?
  3. Re: RIP 2007 Passat? Take a look
    Sep 2008
    SE London
    Get a VAG indie garage to confirm that the engine is a "gonner".
    If salvageable, i.e. it cranks by hand, still has compression, etc. then ask the firm to contact UK firm KMB who supply an uprated oil pump that will not have this in-built TDi design fault.
    You may have been lucky and caught the engine on switch off before any bad damage has occurred.
    Or you may not. Depends what is in the sump as an indication.
    Sump cover needs to come off anyway to get to the oil pump after draining engine oil.
    Do NOT just change the oil pump shaft. The keyway will be well rounded off by now.
    PM me your email address for return attach on the information I've saved as seen in the forums. Word .doc
    I don't have a TDi but there are many experts in here that have been following this fault, and do have the same engine, have experience
  4. Re: RIP 2007 Passat? Take a look
    Nov 2016
    Norway
    Thanks for your post RichardSEL, the shop will drain the oil from the car tomorrow to see what is going on. Im guessing that the garage will deciede what is "too much" metal shavings.
    I will ask them if the engine has compression. It does crank by using the ignition, but it dies, because of the oil pressure i assume.
    How much is the new upgraded oil pump? How many hours does it take to change?
  5. Re: RIP 2007 Passat? Take a look
    May 2012
    Everywhere
    308 Post(s)
    Engine code ?
  6. Re: RIP 2007 Passat? Take a look
    Nov 2016
    Norway
    Not sure, where do i find that?
  7. Re: RIP 2007 Passat? Take a look
    May 2012
    Everywhere
    308 Post(s)
    Build sticker .
  8. Re: RIP 2007 Passat? Take a look
    Nov 2016
    Norway
    Car is at the shop atm, but i will update this thread tomorrow.
  9. Re: RIP 2007 Passat? Take a look
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by Gazwould View Post
    Engine code ?
    BMR or BMN as they are about the only two 170s out there for 2007 / 2008 most likely to be BMR.
    Mad Mitch
  10. Re: RIP 2007 Passat? Take a look
    Sep 2008
    SE London
    Magnus... Car MUST NOT be started, or tried to restart without oil pressure in this condition
    You will only compound any damage already done
  1. Question 2007 passat b6 1.9
    By marty35 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-05-2015, 10:26 AM
  2. Question Passat 2007
    By Gabone CGF in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-12-2010, 11:49 PM
  3. passat 2007
    By ebbw in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-12-2009, 10:41 PM
  4. Passat 2007
    By dru07 in forum New Member Introductions
    Last Post: 17-05-2008, 07:15 PM
  5. 2007 Passat
    By mikem in forum Passat - Archive Topics
    Last Post: 08-05-2006, 11:42 PM
