Thread: Fabia SDi - Problems
Results 11 to 20 of 24
  1. Re: Fabia SDi - Problems
    134 Post(s)
    2007 Post(s)
    Yes COI is the pump timing.
  2. Re: Fabia SDi - Problems
    Feb 2009
    Preston
    Great stuff, It's booked in for the cambelt, and I will advise them that this needs adjusting as part of the replacement. I will update this on Wednesday with an outcome and check injector 4 again. Thanks for your help Crasher!
  3. Re: Fabia SDi - Problems
    Feb 2009
    Preston
    *UPDATE*
    Got the cambelt done and it is running a lot better, not as much smoke now but still some when I accelerate.
    Having a quick look it looks like injector 4 is gone! I have attached a couple of screenshots of Group 013 and 004
    I take it the next course of action is new injector.
  4. Re: Fabia SDi - Problems
    134 Post(s)
    2007 Post(s)
    Possible, you could move it to 1 or 2 and see if the problem moved.
  5. Re: Fabia SDi - Problems
    Feb 2009
    Preston
    Good call, worth a shot.
    Any advice on removing the injector? I have never worked on an SDi injector, all I know is you need to replace the seal. Having a look at some workshop manuals it looks like the suggest using a special puller?
  6. Re: Fabia SDi - Problems
    134 Post(s)
    2007 Post(s)
    It should come out, you are supposed to renew the seals but for a quick test.
  7. Re: Fabia SDi - Problems
    #17
    Feb 2009
    Preston
    Great, so it would be - Clean area - disconnect fuel pipe from injector - undo pide at pump side and lift it back - pull said injector out of the hole and swap.
    Will give that a bash over Christmas!
  8. Re: Fabia SDi - Problems
    #18
    134 Post(s)
    2007 Post(s)
    I use special nylon an brass brushes for bores and mounting surfaces like this which must not marr the surface and gently soft wire wheel polish the seat face of an injector being re-used (NOT the pintle) and to reuse a copper washer anneal it with some heat and when cool, polish off on some 1000 grit on a grade 2 flat bed. Keeping grit out of the bores is imperative and a compression test glow plug adapter with some air pressure in there keeps the crap blowing into your face instead of into the bores.
  9. Re: Fabia SDi - Problems
    #19
    Feb 2009
    Preston
    *UPDATE*
    Tried swapping injectors 1/2 with 4 - and also put a shiny new one in 4 /2/1 and I ALWAYS get the same result - injector 4 1.88!! what does that mean??
  10. Re: Fabia SDi - Problems
    #20
    134 Post(s)
    2007 Post(s)
    Check the compression....
  1. Please Help Fabia immobiliser problems
    By kateb in forum Fabia
    Last Post: 11-08-2015, 08:54 AM
  2. Please Help Fabia 1.9 SDI - running rough, no power, is it the ecu?
    By GRAHAM COGSWELL in forum Fabia
    Last Post: 05-01-2013, 07:52 PM
  3. 2005 mk 5 sdi problems
    By mbev51 in forum Golf MK5 - 2004 - 2009
    Last Post: 12-10-2009, 02:01 PM
  4. Question How reliable is a 2000-2001 Fabia 1.9 SDI
    By harry100 in forum Fabia
    Last Post: 21-07-2009, 06:07 PM
  5. Fabia 1.9 SDi Starter Motor
    By deputy899 in forum Fabia
    Last Post: 04-12-2007, 11:37 AM
